Question about GE Monogram ZISS360NRSS 36" Built-In Side-By-Side Refrigerator (ZIS-S360NRSS, ZIS S360NRSS)
No matter what i set the frig to it goes to 24 degrees and freezes everything.
  • 2 more comments
  • maximuspalme Mar 05, 2009
    man thanks alot.. .i got this frig cause of this problem. Is there a manual besides the bad one that comes with unit. A sevice manual for the unit to help with the actual disassembly of the unit. I wish you lived in vegas. I would put you on the problem for a price. Finding a good repair service here is very difficult. If I had a manual I would attempt the repair for sure.
    thanks again. you are a guru
    mike p.
    no
    no
    no
    for the questions above.
    thanks alot...
    mp
  • Jeff Badger May 11, 2010
    I might be able to help you, but I need to ask you a few questions.
    1. Do you have moisture build up at the bottom of your freezer?
    2. Does your fridge make a gurgling or unusual popping sound?
    3. Is the cooling coil (the metal grating on the back) clean?
    Let me know, and I'll see what I can do for you.
    Lequarius
  • 410 Answers
Its funny you posted this problem as I have just finished working on a built in ge with the exact same problem!
any way whats happening is the dampers that control the quick chill area of your refrig arent opening and closing properly causing subfreezing temps in the fresh food comparment. the parts need to repair your unit are the air handler WR31X10023 and seal WR60X10116 these parts are abot 300.00 dollars. I would recomend calling a good service company to repair this for you but if your mechanicly inclined you could do it yourself. the airhandler is the component behind the crisper drawers in the fresh food section of your refrig.
Hope this helps and please post back if you have any questions thanks Peyton
Posted on Mar 05, 2009
  • peyton thompson
    peyton thompson Mar 05, 2009
    unfortunatley there isnt even a good manual for service techs. GE is very funny about that. Thats the main reason I recomended getting a good service company it might would even serve you better to get GE service if they are in your area. I'll post the service pointer that tells about this problem along with the fix later today so that you can have it as a reference for getting it fixed.
I want my frig to be 33 degrees
...???.. why.. it will freeze almost everything...my temp is 36* and if I leave a pitcher of tea for three days.. the top is 1/2" thick with ice..it freezes lettuce if its anywhere but the door... 33* is too cold for a refrigerator/freezer. My (GE) settings are from 0 (off) 1-7..7 being coldest.. I run mine on 1 except for July-August... then on 2.. and it freezes almost everything...(guess I have a good one?!)
Make sure the seal is good and its CONTACT SURFACES ARE CLEAN and the sealing area is not obstructed..
Aug 29, 2017 | Refrigerators
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Jun 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Everything in frig is freezing no matter what setting we put it on
It looks like the refrigerator won't stop running not matter what temperature you set the cold control and that is the problem ,its need to be replaced.
May 01, 2009 | Refrigerators
Everything in the refrigerator is freezing
The 37 degree reading you're seeing is the temp. setting, not the present actual temp. When it jumps back to 22-25 its telling you what the actual temp is inside the refrig....simply wait about 24 hours. It should then read about 37...that is, the temp you set it at 24 hours previously.
Nov 23, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
