Question about JBL Simply Cinema Satellite Speaker (Each)
No sound in 2 of my 5 JBL sat125a speakers
System was stored for a few months and now after hooking up, 2 of my 5 JBL sat125a speakers have no sound and all wiring is correct.
    Novelist:
  • 91 Answers
Check your speakers on another source to cancell out if it,s truly the speakers , if not then you could be in stereo mode which would explain the three front speakers ,mains and center working! other then that unplug and reset ,and if not that then their is an internal amp issue with your system , hopefully you can get it working ,if not check your warranty and see if the manufacturer will repair or replace for you , hope i was able to help you ,please leave a nice rating if i was of help thank you Sincerely glenn mayer
Posted on Mar 05, 2009
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
Mar 16, 2014 | JBL CREATURE II Computer Speakers
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
JBL Simply Cinema Satellite Speaker (Each) Logo
178 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
