Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
My HP photosmart A520 Printers ink wont align
I have tried to align it several times and still no good. It says after it prints out half of it and then says alignment failed. It then tells me to consult the manual which is no help. I have just tried to print but the picture comes out red. Help!
  • Anonymous Mar 08, 2009
    Have the exact problem...Am lloking for a solution, but have not found one yet. Docs are useless....
I had the same problem with mine when I bought it. The print head is in the ink cartrige not the printer. If it prints all red, blue or yello one of them is stuck, this happened on the trial cartrige that came with it. I put a fresh 110 in it and it aligned and I have printed a TON of pix with no problems.
Pat - Houston
Posted on Dec 06, 2009
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
http://welcome.hp.com/country/au/en/support.html
NOTEs:
1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
2. When you are printing a final copy then switch from DRAFT to BEST quality.
Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
Why does my HP Photosmart C3135 printer always print a test page every time I connect it to my computer? What a waste of ink!
that is alignment page just scan it and press the scan button it will complete the process and next time it wont print.
Jan 19, 2010 | HP Photosmart C3135 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart a636 printer will not align
you may need to change the ink cartridge. Turn the printer off install and turn on. also make sure you have the correct ink.
Mar 30, 2009 | HP Photosmart A636 Compact Photo Printer
Hp psc 2410 photosmart printer is printing faintly and only bottom half of words in paragraphs. The color is also faint. I have replaced both the color and black cartridges. I have also run head cleand and...
Try taking out the cartridges and blot the bottom of the cartridge with paper towel wetted with warm water.Repeat several times.While the cartdigdes are out, use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridges.
Feb 01, 2009 | HP Photosmart 2410 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
448 people viewed this question
Ben Johnson
