Question about JVC AV-32D305 32" TV
Channel # will not go away. we have dish and have to have the tv set on channel 3 for it to work.
  • 75 Answers
Should be able to push display button on remote and it should go away if not have to research this unless some one else knows the answer.
Posted on Mar 05, 2009
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Posted on Apr 29, 2008
tvguy171
  • 106 Answers
SOURCE: change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Posted on Dec 19, 2008
PhilwithDISH
  • 123 Answers
SOURCE: need to change channel to 73 so my dish tv will
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Posted on Mar 02, 2011
Find the channel to run DISH
Channel 3 is normal for that. Always have it on channel 3 on the TV set. Then you can work with it. Check your stuff and see is there a switch to set for channel 3 or 4, if none present, put it on 3, then start from the menu to set it up with remote.
Oct 07, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
Feb 06, 2011 | Westinghouse SK-32H240S Television
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
Sharp dtv e202 error was received
Try just changing the channel to the one set up to receive broadcasts. That worked for me-- the TV was working great until I pressed Input and for some reason that changed the channel away from channel 60, which is the one programmed to receive broadcasts from Dish Network. When I entered 60, the message went away and I got my programming back.
Nov 07, 2010 | Sharp Aqous LC-26D5U Television
I have dish network and I just received a new remote I was able to program the remote and can see the channels for dishnetwork but somehow the channel that my tv is set on to receive the signal has been...
Hopefully after 3 months this has been resolved, but if not, here are some simple steps to take. If you are in TV1, where the receiver box is, you want your tv set to channel 3 or 4. Depending on the cables you have, you may need to put your tv on an input. Usually Video 1 or 2. If you are at TV2, the location away from the receiver, you will want your tv on channel 60 or 73. If neither of these work, try to unplug the receiver from the power source for about 10 seconds. Hope this info helps.
Becki Barned
Oct 23, 2010 | Symphonic ST419E TV
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
Guest,
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
Just set up new tv on dish network and eveything
It would be our pleasure to help get that fixed right away.The first thing we want to ensure is that all connected equipment is on;although it may seem like an obvious step we don't want to overlook it. Checkwhat type of cable is used to connect your TV to the receiver. If you are usinga coax cable to connect the receiver to TV1, check the receiver's back panelfor the output name. If your receiver has a "TV CH 3/4 out": Tune TVto channel 3 or channel 4, if it is labeled "Home Distribution":Tune TV to channel 62 or 75. More than likely you are using a non-coax (RCA,Component, or HDMI) cable to connect receiver to TV1, in this case we want tocycle through the inputs of your until picture appears; most TV's have a"TV/Video", "Input", or "Source" button either onthe front of the TV or on the remote. We also want to ensure that the TV andthe receiver are connected properly, visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingthe same cable, on the same input/channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
Feb 21, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
JVC AV-32D305 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
