Question about Canon PIXMA iP3000 InkJet Photo Printer
How to replace ink absorber - Canon PIXMA iP3000 InkJet Photo Printer
    Novelist:
  • 98 Answers
I suggest that instead of replacing , first try cleaning the ink absorber unless of course they are completely worn out.
Most Canon ip printers have similar construction there :Try as below:
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. They each sit in a rubber socket. The pads can be removed and cleaned.
Take the pads out of the socket with tweezers. Clean them with warm water. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running tap will be sufficient. If there is ink in the socket after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the socket and you have successfully cleaned the ink absorbers.
Please also check the link below on tips on FixYa itself
http://www.fixya.com/support/r883355-ink_absorber_pads_cleaning
All the best... let me know if you require any further help.
Please do rate and thank for using FixYa!
Posted on Mar 05, 2009
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 19, 2012 | Office Equipment & Supplies
Canon ip3500 series the ink absorber is full contact the service center
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Aug 07, 2011 | Canon PIXMA iP3500 Printer
INK ABSORBER FULL
Your waste ink absorber is FULL. So you need to replace your waste ink absorber to the new one.
This problem can not be solved by the user. You must take or send it to a service centre, where a technician will remove the old ink absorber, clean up any internal ink mess and enter a reset code to clear the "ink absorber full" condition.
May 27, 2011 | Computers & Internet
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is almost full problem is for cannon 1800
Hope you find this information helpful. The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My pixma ip1980 ink absorber is full. how to change or clean manually?
You can't. Here is what Canon says on their website:
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Jan 07, 2011 | Office Equipment & Supplies
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
144 people viewed this question
old marine
old marine
