Question about Linksys Wireless-G WRT54G Router
Connection problem using telnet and web...
I hava a WRT54G v2.2 with OpenWRT Kamikaze firmware.
While I am setting the Internet, accidently I changed the Local IP(192.168.1.1) and then click the save button.
As a result My router was down. At that time I could access via telnet. So I did. Using telnet I typed command 'reboot -f' and it was down again.
Now I hava nothing to access my router..
In addition reset button is not working.
Is there any solution??
    Scholar:
  • 135 Answers
Not a definite solution but there are two things you can try.
Firstly, disconnect all cables and power supply to the router and leave it switched off for a minimum of 10 - 15 mins.
Reconnect everything and wait until all the lights on the router stop flashing.
Finally, go to the wireless icon on the toolbar, rick click and select "repair". This will reset the wireless adaptor.
Good luck.
Posted on Mar 05, 2009
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Looking for an updated firmware version for model WRT54G
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Linksys router needs resetting daily to establish Internet connection. Cable modem, hard wire and wireless xbox, laptop and I pad all not used at same time if that matters
Try to update firmware. Open your web-based settings for the router and click on update button. Follow instructions.Hope this will help, because I have same router and had same problems.
Oct 26, 2010 | Linksys Wireless-G WRT54G Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
TRY
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
I got this router from ebay and now i need set up a new network on my pc but it wont detect my router
Try resetting it to factory defaults, and verify it is operating through the wired Web interface. Check it using some other wifi-capable device (other PC, PDA, iPod...).
For basic configuration, you can find the manuals on the linksys web site.
One thing: the WRT54G is quite desirable for hackers because it can be easily modified. BUT, if this was done wrong, you might end up with a "bricked" WRT54G. And maybe decide to peddle it on eBay?. Should this be the case, you can try reflashing it with an original firmware. It usually works. Here the documentation and links:
http://rick.vanrein.org/blog/openness/openwrt-reflash-2005-09-22-14-05.article
Also, here you will find lots of help (on standard configuration too). Properly ****, the WRT54G is one mean son of a gun :-)
http://www.linksysinfo.org/index.php
Jun 09, 2010 | Linksys Wireless-G WRT54G Router
Whenever i am using wireless, my internet will shot down. How can i fix this problem? thanks.
With the wired connection is it working fine ?
If yes and if you have only problem with the wireless connection then try to upgrade the firmware of the router.
Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Apr 17, 2010 | Linksys Wireless-G WRT54G Router
Internet connectivity problem
try to upgrade the latest firmware for the router and reset and reconfig it..
Dec 27, 2007 | Linksys Wireless-G WRT54G Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys Wireless-G WRT54G Router Logo
199 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
