Question about Goodman Heating & Cooling
My blower motor went out in my home and the heat pump package is 15 years old so when i wwent to purchase another one the said it was the one to replace it but its not putting out properly
  • Perry Putnam
    Perry Putnam May 11, 2010
    Are you sure that you are using the high speed wire on the motor?
  • 306 Answers
Make sure you have the rotation of the motor set right. There are two wires hooked together that determine the rotation clock wise or counter clock wise. If it is not blowing any air then go to the motor and switch the two wire around. It will be something like purple and yellow just hook purple to yellow and visa versa.
Posted on Mar 06, 2009
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
Home spa repair
don't shut your spa off for several month let alone weeks with out draining it OR .. the chlorine settles in the pump ruines the seals and leaks water in to the motor or the rotor can rust to the armature. try blowing the motor windings with a soft tipped blower and spinning the rotor from the back of the motor ,should be a cap to remove that you can use a flat blade screwdriver to help spin the motor over.. best bet is to pull pumps and have them serviced. look for a guy that fixes pumps and haves good reviews, it's hard to find a guy to work on these as they are a real pain to service if the are not maintained . i tell everybody the should be serviced when there are NEW and in the future when they need service they will come apart EASY AND COMPLETELY and can then just get a simple tune up. I have the original motors in my spa 15 years old, how old are yours ? the blower did just go out although and my spa has a total of 4 pumps in it .. jay the pump guy longwood florida
Dec 06, 2011 | Pool & Spa
Old a/c package unit add on heat
check your wiring coming from the thermostat should have 24 volts at common terminal and W terminal W is usually used for the heating side. once this is working check to see if you have 24v between common and G which is usually used for the fan motor. if that is good make sure you have full high voltage going to the motor itself find its wires and where they are connected. if it was a low voltage issue and you dont have the 24 volts somewhere in there i was talking about try rewiring the system according to the OEM wiring diagram. You can probably get one on the internet if you google your model number off the unit and its make.
Sep 20, 2009 | Weather King 10AJA2501AH Air Conditioner
Air handler fan not working
Check the fan relay switch in the air handler.
Check the fan motor capacitor.
Check the fan blower wheel for binding.
May 25, 2009 | Heating & Cooling
Spa tub motor need replacing
I havent seen to many motors this old, but today all you really need to know is the horsepower and the frame (either round or square). Pull the old one off and take it to a pool store, and they can probably get it for you.
Also..im not sure but i think A.O. Smith bought out magnetek some years back....
Mar 30, 2009 | Pentair Ultima Series Pump Part Heat Sink...
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
