Question about Cobra 148 GTL 120-Channels Base CB Radio
When I key the radio the meter pegs in s/rf mode.
This is an old 148 that was in a motor home that was sitting for the last 15 years the face was green and the meter a little sticky,So a friend of mine put a new meter in it.Is their a potentiometer on the board that i can turn to fix that? Thanks Chuck. PS the radio was made in taiwan.
  • 1 more comment
  • cdz Mar 06, 2009
    It is the same meter,Their was no resistor between the terminals ,im still not sure what to do.
  • cdz Mar 07, 2009
    Thank you sir, That solved the problem.AAAAAAA+++++++++
  • cdz Mar 07, 2009
    Thanks that worked Thank you AAAAAAAAA+++++
  • 40 Answers
There is a pot inside the radio to adjust the meter. if the meter did not come from the same type radio then most likely it is not the right one all meters are not the same there is also a resister that jumps across the terminals of the meter that needs to be there to keep the meter from banging the side when you key the mic.
Posted on Mar 05, 2009
  • james morgan Mar 06, 2009
    FIRST REMOVE THE COVER ON THE SPEAKER SIDE OF THE RADIO.UNPLUG THE SPEAKER AND SET THE COVER TO THE SIDE. LOOK TOWARD THE BACK OF THE RADIO AND FIND VR6 TX SIGNAL. WITH A ANTENNA ON THE RADIO KEY THE MIC TURN THE POT WITH A JEWLER SCREWDRIVER AND ADJUST THE METER UNTILL YOU GET THE METER JUST BEFORE THE RED MARKINGS AND STOP. THE METER WILL BE VERY CLOSE TO SET AT THAT POINT DO NOT TURN ANY OF THE OTHER POTS THIS WILL MISALIGN THE RADIO JUST TURN ONLY THAT ONE.
    JAMES MORGAN
    MORGANS ELECTRONICS
  • james morgan Mar 08, 2009
    cdz
    glad i could help you. enjoy your radio and have fun doing so.
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
My cobra 142 gtl loses power about two minutes after keying the mic.
hi
it looks like the output stage is going hot (99%)
maby the swr is high end eficiancy is low
usualy on ssb the power is higher than on am
bernard
http://www.rylwy.com/
Aug 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
S/rf is too high on transmit on my cobra 29 ltd bt
no matter what s/rf you are looking at it should not key much beyond an s-9 . vr 3 controls the meter. Key the mic and adjust it to s-9 then check you modulation.If you still think you need more then adjust vr 4 .
Jan 07, 2012 | Cobra 29 LTD CB Radio
Radio quits after 15-30 seconds
without more detailed info, quick suggestion - thermal fault, if all TX audio works when in this fault condition, it may be fair to assume audio IC is ok and check electrolytic capacitors and dry joints.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Rf meter does not work
Does the radio have any rf output? Use a swr/watt meter to check. If if doesn't have any output that would be the cause of the problem.. then its another issues..
May need some test equipment to find the fault on that one.
You could send it in to us and we can fix it.
We do not charge to look at any radio -no bench fees-..
Let me know Ill get you any info that you need.
Oct 19, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
NO AUDIO / NO TX
OK bare with me now i have no idea of your knowledge level with CB/ SSB radios.
Lets make sure our setting on radio face is correct before we decide this is an mechanical problem.
Set the following
  • Volume knob 12 o'clock
  • Dynamike knob 12 o'clock
  • Squelch full counter clockwise
  • Rf gain full clockwise
  • Select S/RF position on the SWR/CAL switch
  • Select AM position on the USB/AM/LSB switch
  • Select CB on the CB/PA switch
Now there will be some critics with opinions on the next instructions. Place a small screwdriver or test lead from a multimeter in center conductor of antenna jack listen for onair noise or radios operators to verify RX is working. Now remove the antenna/screwdrive/testlead. Then key mic just long enough to notice if the meter is swinging do not hold the mic button long this can damage the final. I tell you to do it this way rather that connected to your antenna system so we can eliminate the question if it is you antenna sytem or the radio.
If the LSB or USB was selected when you keyed the mic you would see no meter movement this is due to the lack of a deadkey or carrier for SSB which is a much more efficient method of transmitting on AM.
There are few things that affected the rx and tx together.
Aug 16, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
148 GTL 120-Channels Base CB Radio: my 148 throws a key to my bench radio but sends no...
Hi
try replacing the transistor just before the last on the rf pa output.
Hope this helps
Ray
May 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
148NW ST No TX AM or SSB
finals need to be replaced, as they are fried,, hence no output,,and if you are lucky you haven't fried the pre-amp as yet....as the pre amp is REAL EXPENSIVE....so stop keying it up
Jul 27, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
82 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
