Question about Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp LC-42SB45U I bought a surround sound and hooked it up as instructed, playing a dvd is great as well as the stereo. However, I can not get the cable on the TV'y to work. I was told to turn on the the audio but I can't seem to find how.
    President:
  • 814 Answers
You Have to check The owners manuals for both products to see if you are using the correct switching method to use your television with the surround sound.There is usually a setting for each unit that must be set for the correct signal path to the amplifier output to the speakers. The way to test this out is to use the first input on the surround sound unit for the television. Hook- up the output of the sound for the television to first input on the surround sound amplifier.Set the surround sound amplifier to the first setting and test to see if it is working. If still not working check the televisions sound output section in your owners manual and see if you have to set the output to the line out sound and turn off the television speakers output.If this is true make this adjustment with the on screen menu and test the sound again.If still no sound output there may me a problem with the output sound section of you television. You should then check the Sharp website for the frequently asked question and troubleshooting sections to see if similar problems have been posted for this problem and have answers.If all this fails you should contact customer service for both units and ask for technical assistance for your problem. Hope this helps you with your problem.
Posted on May 12, 2009
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
I HAVE AN INSIGNIA MODEL # NS-H2001 SURROUND SOUND SYSYTEM WITH A BUILT IN DVD PLAYER AND I HAVE SURROUNG SOUND WHILE PLAYING DVD'S BUT I CANT GET SURROUND SOUND ON TO PLAY FROM MY TELEVISION AND I WAS...
It will depend on the signal you get from television stations, as well do you have this running through a stereo, the t,v. I mean. Depends on a number of things as D.V.D's are recorded a certain way such as with "Dolby THX" for instance. If I am right, you are running your television with built in dvd through a home stereo, am I correct?
Aug 23, 2008 | Insignia Televison & Video
Surround Sound using the video feature
You will not get 'surround sound' from this set only stereo sound. The Video/Aux jack at the back of the unit is an input terminal. You can connect the audio part of your TV(if it has a Line Out jack), dvd player or video game console to this input to get the sound through the stereo system. Use a male-to-male RCA cable to make the connection, they are color coded (Red and White). Press the "Video/Aux"  button to select the input terminal.
Nov 04, 2007 | Sharp CDBA3100 Remanufactured Mini-System...
RCA RTD215 surround sound
I could only get surround sound for DVD, NOT cable/TV--regular audio jacks only give stereo for cable/tv, NOT surround sound. Very disappointing. Any thoughts/solutions for how to get surround sound? Cable box has digital output, but no input on the rtd 315, any help available? THX
Nov 01, 2007 | Audio Players & Recorders
Dvd "Highlander DVX4533 " no sound
sounds like it is set to 5.1 surround when you only have a stereo tv hooked up to it. In audio settings you will need to select 2 channel out.
Jul 29, 2007 | Proscan PS8600
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
436 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
