Question about Vodavi IP7024LD Corded Phone
How do you program phone for headset mode on sts phone and where do you plug it in?
  • Neil Johnson
    Neil Johnson Feb 05, 2013
    cswroe-i have the plug on the side of the phone for the headset jack but i am unsure of how to turn to headset mode...i know i have to dial 634 but at what point and how....lets start with the phone on the hook....what do i do from there as far a what buttons to press and dial in 634 and the Flash 50 you describe below...please...and thanks
  • 4 Answers
Some phones have jack on the side of the phone. If it does not, you will need a standard telephone headset with amplifier. You will need a handset button (634) programmed on the phone. Then in programing Flash 50 button 4 you will need to disable speakerphone. Flash 50 button 18 determines the headset type: 0-is amplified unit plugged into handset cord, 1-is 2.5mm jack on side of phone,
To use handset, press handset button so it is lit, use on off to answer calls with the handset.
Posted on Mar 05, 2009
Just purchased a headset to use with my Mitel 5212 phone but I can't connect it. It's plugged into the back of the phone. All instructions i find tell me to press the headset key on the phone but I...
you have to program a headset button on the phone or hit the blue key (superkey) then hit no until you see headset mode then you can turn it on or off. if you don't see it you will have to login to phone system and program it.
Aug 05, 2011 | Mitel 5212 IP Phone
Can't turn off hands-free mode
It might be in headset mode. Press the on/off button then 634 on the dialpad.
Apr 07, 2010 | Vodavi Infinite IN-9014-XX Corded Phone...
I need to know if the vodavi 30 button part number 3015-71 needs a lifter for a headset or not
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
Dec 23, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
How to connect to headset and to use it
First make sure that your headset is compatible with the Panasonic phone, look at the phone left view, there is a plug hole for headset locate at bottom part. After plug in then return to phone to enable the headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
4) Press EXIT or PROG.
YBC (/\)
Jul 16, 2009 | Panasonic KX-T7633 Corded Phone
Headset set up on a KX-T7633
First make sure that your headset is really compatible with the Panasonic phone. After plug in the headset to phone then u need to enable the headset mode. To do this:
1) Press PROG.
YBC (/\)
Jun 23, 2009 | Panasonic KX-T7633 Corded Phone
Trying to set up a wireless headset
There are 2 ways to turn on headset mode. One is by programming, the other is by setting up a button.
BUTTON
Find a spare button of the 24 and label it HDST. Press PROG the button and dial 67 press ENTER then EXIT. When you press the button, the display will say HEADSET MODE ON and the button will light.Press it again to turn it off.
PROGRAM MODE
Press PROG Dial 61 ENTER and then SEL until the display says HEADSET MODE ON or OFF, then ENTER and EXIT.
Both work, but only one give you an indication when it's turned on.
Carl
Oct 01, 2008 | Panasonic KX-T7630 Corded Phone
Headset on DTU 8D-2 corded phone
If you are using the headset jack on the phone, a headset key needs to be programmed on the the phone. You can do this in program mode and make a line key a headset key. Otherwise you must connect it through the handset. ldtsnj.com
Aug 26, 2008 | NEC DTU 8D-2 Corded Phone
Headset Mode Not Working
Your phone may not be set up to use a headset. You need to look into programming for headset mode. If this is helpful, please post as such.
Aug 04, 2008 | Vodavi 30-Button XTS Telephone
Vodavi IP7024LD Corded Phone Logo
330 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
