Question about Miller Welding Tools
MILLER WELDER AC CURRENT TRIPS UNDER LOAD
I have a miller big blue 300p, when i use the ac outlets it gives out current but after 1 minute it trips out leaving the outlets with no current. I turn off the machine then start it again and it does the same thing, I get an HL.P code 23 it says one of the scr output rectifiers has failed. I ordered 2 rectifiers from miller i installed them and tested them in all the different spots my removing two old ones and replacing it with the new ones but i still keep having the same problem as i stated before. my question is should i buy the remaining rectifiers and replace all of them. don't know what else to do. will appreciate any ideas .
  • 360 Answers
Rectification is used to change AC to DC.... DC is used for welding (these would be large rectifiers) and to excite the rotor in the alternator (much smaller and probably part of the control circuit). If when you weld in AC the same error occurs, check the voltage regulation control circuit.
Posted on Mar 05, 2009
  • 19,396 Answers
If your welder is shorting inside and giving electroshock , it may be covered by Miller as factory defect, providing that you have not disassembled the unit by yourself.
Give them a call at
1-800-4-A-MILLER
    Scholar:
  • 165 Answers
Check out for fuse getting blown out or at any loose connection at the power supplying unit.
    Brigadier General:
  • 8,619 Answers
Hi
Try replacing all the output rectifiers and also check the transformer windings.
  • Rylee Smith
    Rylee Smith Mar 05, 2009
    Also check for the Self-resetting Protection Circuit, it needs to be checked.
My miller blue star 185 wont idle up when you start welding
Check your idle control module,
take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
May 12, 2010 | Miller Electric Manufacturing Electric...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Jan 23, 2009 | Welding Tools
Welding Tools Logo
78 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
