Question about Belkin N Wireless Modem-Router F5D8633au4A
How to get the WIRED light on the router back on
There are 5 blue lights the second one WIRED  is not on how do I get it back on?
  • Matt H
    Matt H May 11, 2010
    Is there any computer plugged into this modem-router using a LAN cable? If not, the wired light won't be on more than likely.
    Scholar:
  • 135 Answers
Disconnect ALL leads and remove the router from any power source and leave it off for at least 10 mins minimum then reconnect everything, the lights will flash on and off for a few minutes, then you should have all your light back on.
:o)
Posted on Mar 05, 2009
    Problem Solver:
  • 13 Answers
They only light up once a ethernet cable is plugged in ( wired connection between appliance and the router ) does not when appliance is connecte wirelessly. if there is 5 open ports on the back of your router there should be 5 blank lights
Sylvania t8 96 ballast
sounds like the lamp, try replacing that!!
May 02, 2012 | Televison & Video
Tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
Tip
How to Configure Belkin routers without installation CD for DSL ISPs ?
How to Configure Belkin routers without installation CD for DSL ISPs :
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
Check for the internet status at the top right hand corner. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
If it is not connected then we need to configure the wired part by following these steps.
Step 2: Click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next.
Step 3: HOST NAME leave it blank or you can type anything there and click on APPLY CHANGES.
Step 4: Now check for the internet status at the top right hand corner. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
The above method is applicable for DSL ISPs only.
List of famous DSL ISPs in US:
  • AT & T
  • Verizon
  • Pioneer Telephone Networks
List of famous DSL ISPs in India:
  • AirTel
  • Bsnl
  • Mtnl
  • Tata indicom
  • Reliance Telecom
Now lets configure wireless part by clicking here...
We had a power outage. Everything is back working expect I cannot connet to the internet. My cable company has reset the modeum and when I plug directly into my computer its fine, however when I plug...
First check to make sure you have all the light on the Dlink router lighting up (i.e. power, internet, ethernet, ect). Weather the lights are good or not, check your cables and make sure they are secure. If all the light are proper, then unplug the router for a few seconds then plug it back in. Once all the lights are on try again. If you are using wireless, plug in wired (ethernet cable) to the router. Depending on your OS and settings, you should see in the lower right hand corner a computer icon. If this has a red X on it, the router is not providing a signal to the computer. If everything looks good wired, try the internet again.
If the lights are not correct on the router and checking the cables did not fix the issue, you most likely have a problem with the router its self.
I hope this helps, if not comeback with more information (i.e. what lights are on the router, the IP address the router is giving the computer, wired works but wireless does not, the more information the better).
Jul 22, 2011 | Computers & Internet
The high beam blue light on the binacle remains on whether dipped or not?
Evidently the high beam indicator light (blue) is improperly wired. It should be wired with the yellow wire going to the high beam of the head light. You'll probably need a schematic to determine where the light should be connected. I'm sorry but I don't have a schematic for that bike. Harley used a white wire for the low beam and a yellow wire for the high beam for years but I think they changed on the late models.
May 20, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
No power to light fixture. Only fan works.
Lights are wired separately. Check the wires that come from the light fixture through a hole in the center of the fan and come out at the top with the rest of the wires. Check wiring diagram in manual. Good luck!
Oct 30, 2009 | Hunter (25417) Ceiling Fan
I need to configure my router through email my case # is 10458377 i have majic jack and cant do it over the phone
Hi
As you havent mention that you want to configure the router
first check is your internet is working when you connect your computer wired with your modem given by your internet service provider, if yes, lets move on to the second step, connect your router and their should be four lights on the router
A. POWER : looks like a circle and a line in it.
B. WIRELESS : looks like a radio sending signals
C. INTERNET : looks like i with a circle underneath it
D. and number light : that shows one of your computer is connected with a wire to the router.
once its done now open the internet explorer on your wired computer
type in 192.168.0.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
On the left hand side their is blue coloum, their you need to click on SETUP WIZARD the very first option,
It says the router can autodetect the internet connection, their select YES and click on NEXT option and it shows the screen below :
a. does your internet cinnection require login, Seclect NO
b. make sure you check all the options that i have circled in above screen shot and click on apply it comes with the same page again
c. now click on ROUTER STATUS under the Heading called maintainence and check do you have any ip address under the internet port if YES then you have your wired connection working now, check that by opening another internet explorer, if its still not working
Then upgrade the firmware from the link mention below :
http://kb.netgear.com/app/products/family/a_id/1297
above mention is the master link for all WGT624 routers select teh version and upgrade the firmware, and steps are mention on the smae link as well.
Once its done follow the same steps to make you wired connection working. Once its done, Lets move on to the wireless connection
a. click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
Till now we have set up the wired connection and wireless connection on router and now lets connect your wireless computer with it
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Oct 26, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lights wont turn off even if netwrk wires are unplugged..
You'll have to hold your reset button down for atleast 10 seconds, or even more, then you'll have to reconfigure you entire connnection at address 192.168.2.1.
However before doing that, try and power down the whole unit for a minute or so and power it back up, then go to you computer's wireless connection and renew your IP address [that's if you have automatically assigned addresses]. otherwise you might have to check that you router and computer are operating on the same page [ by this I mean, if your router is assigning automatic IP, make sure your computer is not set to use a static IP, In my years of network, this has always been problem I have experienced on some routers]
Jun 21, 2009 | Belkin (F5D72304F5D7000) Router
Belkin N Wireless Modem-Router F5D8633au4A Logo
75 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
