Question about Kenmore 44103 Side by Side Refrigerator
My evaporator fan does not come on but my compressor is running. I check to see if my door switch is the problem but it is not. I jumped the defrost switch on the evap. and it started the fan but it wentr to defrost cycle. I, m looking for a primary fan control switch but I do not see one.
  • Kenmore Master
  • 3,361 Answers
From your description of elimination you need to replace the defrost thermostat.
If it is defective the e-fan will not run.
Otherwise, you have a bad compressor or a refrigerant leak in the system.
Posted on Mar 05, 2009
Coldspot 1069430411 evaporator fan not coming on while compressor is running and not circulating the cold air. Also, neither light comes on when doors are open, both bulbs new. New defrost timer, new...
Typically there is a sensor or thermostat sensing the return line (suction line) temperature after defrost, the switch turns the evaporator fan on and off based on temperature, your post suggests either the fan is being powered and not running or the thermostat that turns it on may have failed.
Oct 31, 2017 | Refrigerators
Ice develops at back of fridge
hi chris
dave here hope i can help
I would test the defrost timer, defrost heater or defrost limit switch
TESTING AND REPLACING THE DEFROST TIMER
This timer activates the heater that melts frost in the evaporator for 10 to 20 minutes every 10 to 12 hours. In the process, it turns the compressor off and on. If it fails, the compressor may not run. Or the heater may not go on, eventually causing a hidden ice buildup that blocks the cold-air flow and disables the evaporator fan. An access hole lets you test the timer. If the timer isn't in the control panel, look behind the front grille or behind the rear access panel. If the compressor fails to run turn the timer until it clicks. If compressor goes on, timer is faulty. If unit isn't defrosting automatically and turning timer stops compressor or fan, timer is faulty.
Before replacing timer, spray it with electrical contact cleaner through access hole and turn it a few times. Stop just before a click and wait to see if timer advances on its own.
To replace timer, unplug the refrigerator and open control panel. Remove screws holding timer to panel and pull of leads. If wires aren't in a plug, move then one at a time to new timer.
EVAPORATOR AND DEFROST HEATER
In a frost-free unit, the evaporator coils, their fan, and the deforst heater are located behind the freezer's back wall or under its floor. The fan, which circulates cold air between the coils and the two food compartments, is controlled by the door switch, the thermostat, or both. To check the fan, open both doors, wait for the compressor to go on, and hold in the door switch. If you can't hear the fan running, test the fan(below).
The defrost heater, which melts frost on the coils, is cycled on by the defrost timer(above). If the frost melts before the end of the defrost cycle, the defrost limit switch turns the heater off. The heater may be a metal rod, a wire wrapped in foil, or a coil inside a glass tube. All are tested the same way. Test terminals for the heater are often located in the control panel or under a doorjamb; check the wiring diagram. Or test the heater leads inside the evaporator compartment.
TESTING THE EVAPORATOR FAN
To remove the evaporator fan, unplug unit; open back panel(or floor) of freezer. Then unscrew housing holding fan, and take off leads going to fan motor. With VOM(Volt-Ohm Meter) on RX1, probe motor terminals(except green ground wire terminal). Look for moderate resistance(50 to 200 ohms). Replace fan if much lower or infinity.
TESTING THE DEFROST HEATER
Open control panel. With VOM on RX1, probe test terminals. Look for 15-to 100-ohm reading. If infinity, turn defrost timer(as above); retest.
TESTING DEFROST LIMIT SWITCH
Trace and disconnect leads. With VOM on RX1, probe leads. Look for infinity reading when switch is warm, zero after 20 minutes in working freezer.
Hope this sources your problem
Thank you for using Fixya.com
Jul 20, 2008 | AEG Santo U 86000i Compact Refrigerator
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
Upright freezer quit cooling, compressor runs, interior fan runs. copper line from compressors, 1 is warm and 1 at room temp
Hi..
Try to check this
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Frigidaire Freezers
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
FRIGE AND FREEZER ARE WARM NOT WORKING
Make sure you hold the door switch closed too check if the evaporator fan is working also check if the evaporator coils are froeen up..
Sep 15, 2007 | Refrigerators
Kenmore 44103 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
