How do I adjust the overscan on a Commodore 1702?
How do I adjust the overscan on a Commodore 1702 monitor? I have the service manual, but I've encountered two problems:
1. I can adjust the vertical size, but the vertical position will not move up far enough to center the picture. The adjustment pot (R429) is at its full left rotation. I'm guessing that fixing this will depend on whether I need more or less resistance. If more, I could replace the pot with one that has greater max resistance. If less, I have to replace one of the neighboring resistors with a lower-value one (since I've turned the pot down to zero and it isn't enough). Does this sound right?
2. I can't find the horizontal-size adjustment coil, which is documented as L503(L522).
Any help appreciated.
CoachTim
  • 202 Answers
SOURCE: screen adjust changes when entering/leaving full screen games
When your not playing games does it have this problem? You should update the drivers for the monitor and your video card and even the games for that matter, all of those have updates. Update all of these items and see if the problem still exists. You may try running a virus/spyware/other boogies scan too you never know what ilk they may spread. We'll keep the warranty thing in mind but try the above updates. http://www.viewsonic.com/support/drivers/drivers.cfm?category=1&formName=monitor let me know what happens. Tim
Posted on Mar 23, 2007
SOURCE: Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Posted on Nov 05, 2007
SOURCE: acer x191w monitor background is moved to the right with about 2inches of black on left side.
I tried this and it still does not fix my problem. I went into Menu and hit reset by mistake and that totally screwed up my monitor. Now the left side gets cutoff and no matter what I change the resolution to it does not fix it.
Whjat should I do?
Posted on Apr 15, 2008
SOURCE: Cannot make horizontal and vertical size and position adjustments
OK...I paid a whole $50 for an Apex AT2702 that had [undisclosed] vertical zoom, horizontal shift, vertical shift and width issues. Before I raised hell for the person who sold it to me, I decided to first exhaust all alternative solutions.
I found that in order to tweak these settings, you have to be in service mode and must have a service manual which I can email upon request.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE !!!
1-Reduce your tv volume to 0
2-press the MUTE button on your original tv remote [you'll see "Mute" in red on the screen]
3-AT THE SAME TIME, press MUTE on the same remote and MENU on the tv controls.
This set your tv into service mode [there will be a red "S" at the top-center of your screen.
You'll need the table in the service manual page 47 where there are V-SHIFT, H-SHIFT, V-ZOOM, E/W WIDE default values that will need to be changed. WATCH YOUR SCREEN as you change the values to ensure you don't over do it.
If you have news ticker and sports scores issues, you'll want to be tuned to CNN, FOX, ESPN or whatever to see how your changes are applied.
If you have tv guide problems then tune to that channel or press info and see what happens when you make the changes.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE.
This has worked for my set and you may attempt this solution on yours at your own risk.
I'm no longer pissed off that I got a bogus tv because it now works just fine and I can see everything!
Good Luck!
Posted on May 22, 2008
  • 378 Answers
SOURCE: Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Posted on Jan 05, 2009
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
Dull display on tft monitor
if all adjustment made, CRT monitor are going obsolete.
Nov 09, 2013 | IBM J156-1702 17 in.CRT Conventional...
How to reduce greenish colour on hp 1702
in the main menu of your display buttons on your monitor there is color settings red blue and green wshere you copuld adjust. it this helps please rate with comment
Feb 06, 2013 | HP Compaq 1701 17" LCD Monitor
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
A massage is coming on the screen like "OSD LOcked" how can I close it.Hp 1702 monitor.
sir plz adjust your monitor resolution and it will gone
best regards
if you see that is helpful plz don't forget to vote me
Mar 31, 2011 | Computers & Internet
The picture has ''zoomed'' out. can't read text on scroll bars. fuz
Please try using the zoom button on a universal remote. The button on the remote may no longer be working. Otherwise the best way is to open the set and test each capacitor and transistor with a multimeter to see which ones if any need to be replaced.
Mar 25, 2009 | Sharp 27U-F810 27" TV
Introduction
Coolness..stay tuned, as I have a bunch of plans for those that 'get it ' about team help desk work.
take a peek here
Feb 13, 2008 | Audio Players & Recorders
Overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Dec 28, 2007 | Mitsubishi WS-65313 65" Rear Projection...
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
