Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Would like to install a water filter
Our refrigerator works great, but we would like to install a water filter on the refrigerator. We purchased our home 2 years ago with all the appliances. The water that runs through the refrigerator is softened. We would like an additional water filter to get rid of the salt from the softener.
    Problem Solver:
  • 12 Answers
No worry, I would recommend you to please buy Evoclear system which helps you to provide purest, cleanest, safest, healthiest water ever and most important thing is lifelong customer service and zero maintenance cost. You can think of then to install water filter on the refrigerator.
Posted on Dec 22, 2014
  • GE Master
  • 3,361 Answers
Add a in-line filter to the incoming water line behind the refrigerator.
Most have 1/4 inch compression fittings to adapt.
Posted on Mar 09, 2009
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Have an under sink Culligan RO system with 4 potential filters but it only uses 3 (was so installed by Culligan). Filters are labeled - reading left to right Sediment SED10 ...
Pre-filter and carbon block filter are changed annually. The membrane is only changed every 3-7 years depending on water quality coming in, TDS and usage. Fourth filter is an in-line carbon filter that goes on the line up to the RO faucet.
RJH2O
Aug 12, 2011 | Culligan Compatible RO Prefilter AC30AC15...
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
LG Side by Side - replaced filter now ice/ water will not worl
See if it works when you pull the filter out and try running it (without the filter in). If it works, try buying a new filter and make sure you have the filter that is made for your specific refrigerator. If no water comes out or no ice is made after pulling filter out, than you probably have a obstruction in the line. If thats the case you should have someone come out to fix it. If your mechanically inclined you can try to do it yourself. I would suggest reading the owners manual first, in the "troubleshooting" section.
Aug 05, 2009 | LG LSC26905TT Side by Side Refrigerator
Frigidaire Pure Source 2 water filter keeps popping out.
My parents frig had the same problem. The steel tabs that hold the filter in place are very small and frail. Heres what I did to solve the problem, at least temporarily. While firmly holding the filter release button, gently bend the tabs together using an extra long pair of curved needle nose pliers.
Apr 15, 2009 | Refrigerators
The water dispenser has stopped working!!!
could be a water solenoid problem (at the back portion where water from the sink enters ), or a micro switch in the dispenser area problem.
also, check if u have a water filter. could be clogged already.
tnx 4 using fixya,
drcool
Oct 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge Profile bottom freezer, french door refrig, water filter
Just replace GE's filter with a standard inline filter that hooks to 1/4" water line tubing. Sounds like their filter has no flow rate either...
Here's a popular one:
http://cgi.ebay.com/AICRO-GAC-IN-LINE-FILTER-2-X-10-X-1-4-FNPT-JG-FIT-/390180520853?pt=LH_DefaultDomain_0&var=&hash=item99ab36a9be#ht_500wt_721
Jun 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
