Question about Denon AVR-2308CI
DENON AVR 2308 no longer works only after 3 weeks of purchase!!!
I purchased a DENON AVR 2308 three weeks ago, and although I have not experienced any crackling audio issues, I have had to return the product back to the store I purchased it from because it no longer has any power. There is no display, hence no sound, hence no power.
The store is trying to tell me that an electrical surge caused the problem before they even returned it back to the manufacturer. I personally believe it was a faulty item from day one and I refuse to believe that an electrical surge caused the problem because the AMP was switched off at the time of any possible black outs or storms could have happened, and furthermore all my other equipment (TV, DVD, CD, speakers, etc) are working fine. Has anyone else experienced this issue or can anyone explain if power surges can cause AMPs to blow out but somehow not cause problems to the other equipment hooked up to the AMP?
  • dynamike Mar 15, 2009
    Denon AVR-2106 no audio
    I have a similar problem with 3 years old AVR... Upon turning unit off one day, there was a
    moderate pop sound from all 5 speakers and power light flashed red but
    did not shut off. I shut off. Now when I turn on again, there will be
    several seconds of flashing green, then a very slight power relay
    click-on sound, but no sound any more. To provide 'more details'
    requires opening the box. SOmeone mentioned a thermal fuse, can I pull it
    and exchange it? Thanks... Mike
  • bestel May 11, 2009
    i have exactly the same problem with george. I put all the connection correctly but no light, no power. All other equipments are working fine. I am thinking to take it to a maintenance service to change the fuse.. Any suggestion?
  • 4,234 Answers
You need to get more details. What component has failed that makes them believe that a surge caused the problem. There is usually a thermal fuse inside of the main power transformer that CAN be effected by power surges. WIthout more details, I really can't rpovide any ammunition for your claim. Please request exact details from the servicer.
Thanks,
Dan
Posted on Mar 05, 2009
My new denon 1612 subwoofer is not working
Take it back to the place of purchase, this is a manufacture defect.
Mar 22, 2012 | Denon AVR-1612 5.1 Channels Receiver
Somehow my denon 2308ci's setting got changed. I have cd/dvd play attached, a comcast hd cable box inputted to the receiver then back out to a samsung 1080 lcd tv, and of course an am/fm tuner in the...
It seems you are not unfamiliar with censorable abbreviations.
RTFM and go through all the settings again.
http://www.retrevo.com/support/Denon-AVR-2308-Receivers-manual/id/3837dj882/t/2/
Your unspecified external devices all have settings, cables and (if digital) the ports on the Denon may need to be assigned.
Sep 25, 2011 | Denon AVR-2307 Receiver
I have a denon avr 2308. The sound stoped working
when using an hdmi input, make sure the "input mode" is in 'hdmi' or 'auto'. i am sure you can remedy your issues with a trip through the setup menu. it very extensive. good luck
Feb 10, 2010 | Denon AVR-2308CI
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Response to Denon just shutting off.
we have the service center in new delhi. please call +91 9871371720
Aug 23, 2009 | Denon AVR-1508 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
AM,NEED REMOTE CONTROLL DENON AVR-3802 HOW I,BUY?
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Mar 24, 2009 | Denon AVR-3802 Receiver
DENON 2308 - altering the Bass and Treble
IF YOU HAVE A MANUAL PAGE 40 DEALS WITH HOW TO DO THIS
Nov 26, 2008 | Denon AVR-2307 Receiver
DENON 2308
IF YOU HAVE A MANUAL FOR YOUR DENON THE INSTRUCTIONS FOR ADJUSTING THE BASS AND TREBLE IS ON PAGE 40 UNDER TONE CONTROL IF NO MANUAL FOLLOW THIS LINK TO DENONS WEBSITE http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
Need advice in hooking up avr-2308ci...using dvi to hdmi how do i get audio to surround?
With a little more info, I can help you. What is the source you are trying to play through the 2308? Is the problem that you don't have sound out speakers connected to the 2308?
-Herb
Sep 03, 2008 | Denon Audio Players & Recorders
Denon AVR-2308CI Logo
611 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
