Question about Dishwashers
My GE Profile dishwasher which may be 10 years old has worked perfectly until today. We push start and nothing happens. We have checked the breaker box and all appears fine. What else should I check?
  • 1,800 Answers
  • Check for a blown fuse or tripped circuit breaker
  • Check that the dishwasher is plugged in securely
    or
  • Inspect the wiring connection to the dishwasher for burns or breaks.
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
  • Posted on Mar 05, 2009
      Brigadier General:
    • Dishwashers Master
    • 3,614 Answers
    is there any power coming into the unit. or the unit power up.
    better do turn off the breaker and restart again the machine.
    • micromaster
      micromaster Mar 05, 2009
      check the ff:
      • Check to make sure it's receiving power.
      • If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty.
      • Make sure the door is tightly closed and latched. The dishwasher will not operate until the latch is properly engaged.
      • Make sure the water is turned on and the water temperature is high enough..
      • Make sure the controls on the control panel are properly set.
    Panel is lit up but dishwasher will not run. Pushing the start button does nothing
    Turn the breaker off for 1 minute. If that does not work, the control would need to be replaced to fix the issue.
    Apr 22, 2011 | GE 24 in. Profile PDW7880G Built-in...
    GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
    Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
    Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
    Why is it dead?
    Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
    Apr 14, 2010 | GE Dishwashers
    My GE dishwasher, when i push the start button nothing happens.
    1)check any fuse had gone in electronic board.
    2)check the input voltage to pcb.(normal)
    Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
    GE profile performance dishwasher- not starting after child pushed buttons.
    The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
    May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
    Ge profile dishwasher panel won't turn on
    out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
    Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
    Maytag dishwasher, no power, then flashing lights, now no power.
    Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
    Jeff
    Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
    Drying light keeps flashing
    You said,
    Drying light keeps flashing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again.
    It seems you have an electrical fault in the dishwasher and it will not permit the start of the motor,
    as a safety guard.
    You must have the electrical system checked for shorts .
    Otherwise the motor is dead!
    huuum,happy to assist you!
    How old is the appliance?
    If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
    Therefore they pay for them selves in only a few years.
    You can buy New and save today.
    Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
    Bless You, let me know how it goes.
    huuum
    Please give me a good rating for my fine advice before you sign off.
    Thank You
    Sep 18, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
    PDW7880G-No power to control panel. Just stopped at the end of drain cycle
    Solution Found!!
    Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
    Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
    Open Questions:
    Dishwashers Logo
    Top Dishwashers Experts
