Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Can't connect iTouch to Verizon GT704WG wireless router
I have a Verizon GT704WG wireless router but can't connect my iTouch to it. The iTouch asks for a "password" of which I know nothing about. I tried "password" and "admin" but that did not work. Any suggestions?
    Scholar:
  • 67 Answers
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Posted on Mar 05, 2009
GT704WG wont pass internet connection
need to configure the router again with PPPOE settings on the router.
Oct 20, 2012 | Actiontec (GT704WG) Router
Ip address is needed to connect to my cell phone with this verizon GT704WG wireless DSL?
No. You just need to enter the WEP password when your phone picks up the network's name.
Aug 18, 2010 | Actiontec GT704WG Wireless Router...
I can not connect my ipod touch to internet through my router GT704WG it is saying invalid argument.. And Verizon is no help at all
1. check your firewall permission and your permissions in the router. this should be in the "advance tab:
Try setting up the I pod by MAC address ( media Access code).
Apr 28, 2010 | Actiontec GT704WG Wireless Router...
NO PSN with Actiontec GT704WG Verizon
If you can access the internet it is not a problem with the router. Are you able to access the PSN site but rejected when you enter your credentials?
Feb 04, 2010 | Actiontec GT704WG Wireless Router...
Can I use a verizon actiontec router with Brighthouse sevice and
I went to Best Buy and asked the support staff.THEY WERE VERY HELPFUL.I ended up buying a NetGear router on sale for $40.00 as the Verizon router does not have a ethernet outlet to the computer so it is not able to be used.
Jan 13, 2010 | Actiontec GT704WG Wireless Router...
How can I activat my wireless connection in my
You will need to check the wireless settings of the router.
For that, you will need to access the set up interface of the router.
Here you can change the wireless network name and secure the wireless network.
Click Here to know more about route set up
Oct 28, 2009 | Actiontec (GT704WG) Router
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Failure to Connect
Lights on your router are indicators if the router is working properly or not. These lights are being controlled the the FIRMWARE of the router. If your router is no longer operating normally, you can do a FIRMWARE UPGRADE on your router. Firmware upgrade is a solution but sometimes harmful(it could kill your router). Make sure that Verizon already exhausted all possible solutions to your problem.
If a Firmware upgrade do not solve youe problem, getting a new router is the next solution. If the new router do not fix the problem, YOU HAVE TO LOOK FOR ANOTHER INTERNET PROVIDER.
Good Day
Mar 12, 2008 | Actiontec GT704WG Wireless Router...
WEP address
look on the bottom of the router in small print i'll bet you find it!
Feb 12, 2008 | Actiontec GT704WG Wireless Router...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
404 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
