Question about Reddy Heater Tools 60,000 Btu Portable Kerosene Forced-Air Heater - R60A
Heater starts, runs and then shuts off. It then will start up again when plugged in.What could be causing this?
    Problem Solver:
  • 13 Answers
Your heaters sensor might be broken so that it cant reat the temprature, making it belive that its romm temprature and heat is not needed. easy fix if you know how to replace the sensor.
Posted on Mar 05, 2009
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Car starts then shut it off and wont start again rite away? Heater contrals flash when wont start. wat could that bee?
My Passat would run, then not start for a while, then run fine again. I told the mechanic it acted like old carburetor engines would when they flooded. Took him 3 days to find the problem. The oil pressure regulator was bad, making the pressure to high, causing the lifters to stay open. Had to change the oil pump and fixed the problem. This is a known problem with VW's. ONLY RUN THE RECCOMENDED SYNTH OIL IN THE CAR it makes all the difference
Apr 10, 2013 | 1999 Volkswagen Passat
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
My heater will shut down after running for about 10 mins. there is lots of propane, and all the connects seem to be tight and secure. i've checked the gap in the sparking unit (spark plug) and its around...
Hi check the flame sencer is clean check tubes to pressure switch ,jump out presureswitch , check fan control switch is clean, agian jump this out see if it works then .
Feb 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Runs for 15 secc.'s to 1 Min. Then Shuts off...
Steve- You've got to understandhow it's supposed to work before you can fix it.!
  1. The ignitor only glows for 5 seconds. Just long enough to start combustion.
  2. The photocell monitors the flame color. If it doesn't like the color of the flame (or no flame at all), then it shuts the heater down. Does this sound like what may be happening?
You must troubleshoot the system and decide whether you are having a fuel delivery/mixture problem or an electronics problem.
Read these troubleshooting tips.
Good luck.
Dec 10, 2008 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
94 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
