Question about Philips 9P5040C TV
My 50in projective philips magnavox comes in green model number 9p5040c104
Sounds like a simple problem....Go into menu...then to picture...Should be a Color option: See if it is adjusted all the way to one side...if it is...then try reseting it back to the center. If that doesn't help...Iono
Posted on Mar 05, 2009
I have a 32" Magnavox
The set's model number is on a label on the rear of the set.
As far as a replacement remote do not bother with a universal as most of them do not work or have all the functions on a Philips product (Philips is Magnavox).
With a good model number either call Philips or someone like ANDREWS ELECTRONICS (They are in California but take orders and ship all over--with the model number they will come up with a part number for you and know if the remote is available or not.)
Let me know with a comment here if you have more questions, I am here to help.
SD TECH
Apr 13, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philip magnavox model # 9p6440c105
you most likely need a LSB board. If you go to the following link and leave them a email with your model number and the symptoms they will confirm which board you need , They have some good sales on Circuit boards for the remainder of the month.
Heres the link.
http://servicemanuals.vstore.ca/
Jan 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
We have a problem with the power going off.
Its either the power supply or the LSB. You can get free info at the following link which will help you determine which part you need. Just leave them a email with your model number and symptom.
Aug 10, 2008 | Philips 64PP9751 64 in. Rear Projection...
9p6031c103
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
May 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
60" magnavox tv
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
May 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9P5040C TV Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
