Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Replacement lamp not bright
I have a mitsubishi wd 52725 and the lamp went out. There are alot of places selling lamps with housings from $109-$300. I bought one from advanced lamps for $139 and put it in and my tv is not very bright. My question is what is the difference between lamps. what one is the best quality? the factory one that I took out was a osram. any thoughts? thanks Russ
  • johnnymacc Mar 18, 2009
    i replaced my lamp with osram and get same result, picture is not clear and bright. scenes with windows in them show bright white with subjects dark that stand in front.
As i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Posted on Mar 20, 2009
I have a mitsubishi WD-52725. the red lamp light was on and I replaced the lamp. the red lamp light came back on after replacing with a new lamp. Could there be another problem
Yes the capacvitors on the power board can cause the red lamp light and a 34 error code. The V26 Power repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the upgraded caps and the CD with instructions for the repair.
Jul 03, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
How to reset hours (4000) after replacing lamp
when you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Lamp went, replaced and does not come on
If lamp went out before check F9A09 then C9A37 and C9A38. Also maybe light engine bad. More info at ctechnicians.com
Dec 18, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
