Question about Whirlpool GEW9250 Electric Dryer
Where is the heating elemint - Whirlpool GEW9250 Electric Dryer
  • 5,911 Answers
If the model number you have this listed under is correct, you will need to open the panel under the door. This is accomplished by removing the screws under the bottom edge of the lower panel. HINT: If you prop up the front feet of the dryer, it makes access to the screws much easier.
With the screws removed, the panel will drop down and off. The heating element is located on the right-hand side under the drum, inside a heater box. CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the unit. Dangerous voltage is still present even while the unit is turned off.
Is there any reason why you need to know where the heating element is? Do you have a heating problem? Please elaborate?
If the model number is not correct, please post back with the correct information. If you need further assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
1981 gl 1100 clutch upgrade
ring around the bike wreckers shops for a replacement
Oct 25, 2016 | Motorcycles
Why doesn't the compressor start in the heat mode
If the compressor is off and the heat coil is on - this is normal for the "E" or emergency heat setting. Check for proper connections between the Heat-pump, furnace(heat source) and the thermostat and that the thermostat is capable of controlling a heat-pump with secondary/emergency heat units. Thermostats designed for this have 4 settings: Cool / off / heat / E(emergency heat). in the "heat" setting, both the Heat-pump and Aux heat work together to maintain temperature. In the "E" setting, only the Aux heat source is used. The "E" setting should only be used in extreme cold - when the Heat-pump can no longer produce heat.
Sep 10, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
Hot water is intermittent
Feb 27, 2014 | Camp Chef Camping, Backpacking & Hiking
Drum turns but has no heat
seems to me the heating elemint may be gone. You may have one or two in your unit but if your getting NO heat both may be gone.
Nov 28, 2009 | Dryers
EM HEAT.... does it stand for ECONOMY HEAT or EMERGENCY HEAT? They both conflict. Someone's misinformed.
It stands for Emergency Heat. (Back up heat) . Normally you will find it on heat pumps. It's used manually when the compressor goes out on a heat pump. It's used automatically by the unit when it's so cold outside the heat pump can't keep up. This happens when there is not enough heat in the air to draw heat from. This happens at around 23 degrees. I hope this explains what emergency heat is and what it's used for.
Oct 16, 2009 | Ruud Central System Air Conditioner
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Dryer has no heat, not heating elament
Test the outlet for 240V. If that's ok, you've already replaced the element so remove the wires from the thermostats and test them for continuity (you might want to test the element for continuity just in case). If that's ok, there might be a problem with the timer. Depending on the model you may be able to open it to verify.
If you're still having problems, post your model number and I'll try to assist you further.
Apr 04, 2009 | Kenmore Dryers
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
