Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Mitsubishi wd 52725 lamp troubles
I have a mitsubishi wd 52725 and the lamp went out. There are alot of places selling lamps with housings from $109-$300. I bought one from advanced lamps for $139 and put it in and my tv is not very bright. My question is what is the difference between lamps. what one is the best quality? the factory one that I took out was a osram. any thoughts? thanks Russ
    Genius:
  • Mitsubishi Master
  • 1,039 Answers
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Posted on Apr 25, 2009
I have a mitsubishi WD-52725. the red lamp light was on and I replaced the lamp. the red lamp light came back on after replacing with a new lamp. Could there be another problem
Yes the capacvitors on the power board can cause the red lamp light and a 34 error code. The V26 Power repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the upgraded caps and the CD with instructions for the repair.
Jul 03, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Lamp went, replaced and does not come on
If lamp went out before check F9A09 then C9A37 and C9A38. Also maybe light engine bad. More info at ctechnicians.com
Dec 18, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
626 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
