Question about Capcom Video Game Consoles & Games
I am trying to unlock the engine door on megaman5 that is on the ship
    Problem Solver:
  • 11 Answers
Examine the door and enter the security code:
1 1 9 2 2 9 1 1.
I believe this is what you're talking about? :)
Posted on Mar 10, 2009
How to manuley unlock the rear hatch lift door from the inside on a 2003 GMC ENVOY ? I open the inside cap but can't see how to get it unlocked.
the door is most likely stuck, something caught in it or pushing against it. Make sure there is nothing pushing against the door and then push it really hard to make sure it re latches. I had to do this about 3 times before my door released. I had part of a blanket in the latch. Then try opening door. If that doesn't work ask at any dealer ship for help.
Oct 08, 2014 | 2003 GMC Envoy
Range rover p38 problems
I have the same problem sometimes
1 Check the condition of your battery, if old, it will not give full power required to communicate with the security system.
2 If you don't have the EKA of your RR, try this next time you get caught, put key in the drivers door look, press unlock button on key fob and at the same time turn to unlock, if all locks unlock then the engine should not be immobilized - Good luck
Jul 13, 2014 | 1996 Land Rover Range Rover
The key fob for my car will not unlock the doors or start the engine
You say that your key fob does not unlock the car. Try to open the door ordinary and try to start the car. If the car wont start means that your key fob has lost the program and needs re-programing. The other option is either you by any case confused the key fob with the standard key which is only to unlock the doors. The last senario is when you have opened the key fob to check the battery lost the microchip and that is the reason for not starting. Check following my advice. Good luck.
Aug 17, 2012 | 1999 Nissan Primera
Is the anti-theft deterrant system the same system as the engine immobiliser or are they completely different?
Hello Jaclyn... Your Camry has an "engine immobilizer" designed to prevent "hot-wire" starting incorporated into the anti-theft system...This was standard on the XLE, & an available option on the LE. When the battery cable came off the immobilizer lost it's memory & is not reckoning the chip in the key. Try locking and closing all the doors. Then unlock the drivers door with the key. Repeat this several times, also tap the brake & gas pedal. If this does not help the dealer will have to reset it by the vehicles VIN number.
I hope this information is helpful.
Dec 01, 2011 | 1998 Toyota Camry
1996 jeep grand cherokee laredo: I had just bought this jeep from an owner and i locked the doors yesterday. When i went to unlock the door it set off the alarm. I have tried everything possible to...
put the key in the drivers door lock it with the key still in the lock unlock it and then pull the key out do this three times that is the factory built in security programing shut off system for jeeps and chrysler
Mar 11, 2011 | 1996 Jeep Grand Cherokee
When i try to unlock my drivers door all the other doors unlock but not the drivers door. how do i fix this??
Not too hard but will require the replacement of the lock actuator. The panel will need to come off to gain axcess to the inside of the door. i have a 5 series repir manual which should be close if not the same to repair. if you would like it, let me know. You may be able to locate a used lock actuator in a salvage yard saving you some money. If you have to locate one out of state, most will ship.
Oct 24, 2010 | 1994 BMW 7 Series
How do I open my oven door after a cleaning cycle? We just moved here and my oven door at the old house would just unlock automatically after a cleaning cycle.
You might need to turn the breaker off at the electric box to get this to unlock. And you should try NOT to clean it more than you have to as the heat gets close to 800 degrees and normally takes out electronic parts. I hope this helps you. You can call us for parts if you need to. We'll be happy to ship them to you. Ella
Aug 17, 2009 | Ovens
Several months ago I began experiencing a occasional problem with the anti-theft system of my 1992 Nissan Maxima SE 5 speed manual trans. Using my key I unlocked the drivers door and opened the door. The...
jimmy: it sounds like the drivers door unlock tamper switch or the other switch may have failed. One side can affect the other under certain circumstances. Your trunk lock also has a switch which arms and disarms the antitheft system. Try locking all the doors, make sure the hood and trunk lid are closed and then open the trunk. Leave it open open the drivers door and try to start the car.
If it's a no start. Disconnect the ground battery cable then put the ignition key in the run position in you ignition switch. Reconnect the battery and try to start the car. It should start. This usually will override the anti theft system. One issue with this will be, whether the antitheft system will remain disarmed.
Although I have never tried this before, I know that the system will not arm unless all the doors, trunk and the hood are closed.
I could suggest this to try if the car starts as I had told you pertaining to disconnecting the battery cable, I would take the switch and unbolt it from the passenger's side of the engine compartment just forward of the shock tower. Just let it sit somewhere so it doesn't get caught up in anything moving. If there is a light under the hood of your car, remove the bulb.
Let me know how you make out.
Mar 30, 2009 | 1992 Nissan Maxima
Alarm problem on 2004 chevy tahoe
you will have to write your vehicles vin number down wich is if you look throught the windshild on the drivers side you will see it its a little plate with numbers but right down the vin number and take you drivers license and Registration with you to the chevy dealer ship and request the remote for that vehicle. and they should be able to get you one. as far as i know the remote is the only way to get the alarm off. I hope this helps you
Mar 21, 2009 | 2004 Chevrolet Tahoe
Broken (or stuck?) driver's side door mechanism
Just go to a junk yard and pull them off a junker and put them on yours. Simple fix with a screwdriver. Most Toyota stuff has already been shipped out to Japan so you may have to go to a dealership for them. I can understand what your saying friend about cash limitations, if someone told me to pay attention I'd have to take out a loan. You'll work it out somehow. You may have to just hook a wire to the handle mounts to pull them unlatched. As for the one not unlocking, pull the inside panel off and unhook the lock and unlock it. Luck toya Bro.
Jul 07, 2017 | 1984 Toyota Tercel
Video Game Consoles & Games Logo
109 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Adam Jasar
Level 1 Expert
James Wishart
seanwalters1
Level 1 Expert
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
