Question about Onkyo TX-SR803 Receiver
Onkyo tx-sr806 reciver ''DTS HD''
My Onkyo 806 reciver connected with panasonic bd35k blue ray plaer and its decode and bitstreem DTS HD 7.1 audo and i tryed to play DTS HD 7.1 featured BD Disc via hdmi connection between player and reciver but reciver accepts only 5.1 and shows DTS Neo 6 ???
i selected onscreen menu dts HD 7.1 CH in BD player but still its showing the same..? how i get DTS 7.1 hd lossless audio
    Novelist:
  • 98 Answers
Hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
Hello what is the best setting for ps3 slim when played through onkyo 608 pcm or bitstream at the moment it is saying multichanel on the amp if i change it to bitstream it says on the screen some audio...
Bitstream will pass the HD digital audio directly on to the receiver, in either DTS or Dolby format. This allows your receiver to decode these formats. The Onkyo TX-SR608 is capable of decoding all the new HD audio formats, and has quality Burr-Brown digital-analogue converters so it would be a shame not to use bitstream in my opinion.
Electing to output the sound as PCM will utilize the PS3's internal digital audio decoding, and I believe output a two channel analogue signal... which your receiver will then reprocess into simulated surround sound... not ideal really.
Jan 06, 2011 | Onkyo TX-SR608 Receiver
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Oct 28, 2009 | Audio Players & Recorders
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo TX-SR806 7.1 Channels Receiver I bought a reciver just 4 days back. It worked fine for 2 days and yesterday when i tried to increase the volume, it shut off. I tried troubleshooting to see if there...
If you have disconnected all connections from the receiver including your sources and the unit shuts down and goes in protect then there is an internal shortcircuit on the receiver and you would need to send that to an authorized service center. Now, since you just bought it 4 days ago, if you purchased it from an authorized dealer of Onkyo you could have it replaced since its way within the 30 day return policy. But, if you have purchased it from circuit city, unfortunately your option would only be the service center for repairs. If you send it to an authorized service center, you would need to put in a copy of your sales receipt together with a brief description of the issue you are encountering. Where did you purchase your 806?
Mar 03, 2009 | Onkyo TX-SR604 Receiver
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR803 Receiver Logo
856 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
