Question about Brother PT-65 Personal P-Touch Electronic Labeling System Printer
With a pt 65, how do I reduce the size of the print?
I have a P-touch, PT65. I don't have a manual. Where is the button to change the size of the print? Or better yet, how do you change the print size?
    Scholar:
  • 56 Answers
Cook,
With the unit powered up, press and hold the yellow Code button. While holding it down, press the & key and watch the pointer at the top of the screen. Note how it is moving to the various size As. That will increase and decrease your font size.
Posted on Mar 05, 2009
  • Damon Gray
    Damon Gray Mar 05, 2009
    Cook?? What more did you need? That's exactly the answer to your question. Why did you not rate that a full FixYa?
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
How do I change font size on p-touch 1880? I don't understand the manual.
To change the Font Size follow as below.
Press the 'Fn' Button
Then using the '' Buttons move to SIZE and press the 'OK' Button
Then again using the '' Buttons select which Font Size you require (Large, Medium, Small or Max) and press the 'OK' Button.
Jul 30, 2011 | Brother P-Touch PT-1880 Printer
I want a manual for this product here, in the internet
The manual for the PT65 can be found at the link below.
http://www.ptouchdirect.com/ptouch/manual/PT65.pdf
Robert from Blitware
Jun 15, 2010 | Brother BRTPT65 PT-65 Label Maker Printer
Model PT-1900/1910 operational manual is lost.
I assume that you need the manual for your printer.
Here you can download:
http://www.ptouchdirect.com/ptouch/manual/PT1900.pdf
On page 26-28 it explains what you need to do to change the size of letters.
Apr 09, 2010 | Brother P-Touch 1900 Label Printer
Unit won't turn on -is it dead?
I had a problem in that I purchased cheap batteries. Brand new out of the box at least three were bad. Confirm your batteries are OK by using them in other electronic items. Even one battery too weak or bad will cause a problem.
>I'm also assuming that you have correctly replaced all the batteries back in the PT65. My mother always puts one battery in wrong and needs help. LOL...
Apr 26, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
How do i load tape in pt 65?
Remove back cover by pressing down on dots. Make sure you have the correct size replacement (they start with an M and are 9mm or 12mm).
Put the side of the tape that has the open V in it over the silver metal holder in the PT65. Snap the left side of the cartridge in. This should line up the black roller with the exposed part of the tape.
Snap the lid back on and turn on the unit. Hold the CODE button and press the space bar so some of the tape feeds out of the top.
Apr 23, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Cannot remove backing
Bend the label in half length-wise
Mar 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT-65 Personal P-Touch Electronic Labeling System Printer Logo
316 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
