Question about Saeco Vienna De Luxe Espresso Machine
Saeco Trevi leaks from "inside"
My Saeco Trevi(like Vienna) leaks from inside to underneath the machine. It seems to only happen when making coffee. If I pull out the drip pan it is quite wet underneath it. The drip pan has a "tongue" on it and wondered if it wasn't seating right but now I think it may be a seal or O ring. Anyone experience this before? I once had a leak from the resevoir, but this is different. Are there "kits" sold with the necessary replacement rings and if so where? Thanks in advance.
  • Anonymous Apr 14, 2009
    same water leaks from bottom when making coffee
  • 4 Answers
What can have happened is that through an overflow of used coffee the hole in the back is stuffed with the ground used coffee. The way to solve this is getting out the brewing group and rinse the hole with water after removing the cloggin coffee residu. You can find this hole just beneath the outgoing axle.
Posted on Mar 22, 2009
My Saeco Vienna Deluxe has water leaking out from somewhere underneath - clear water.
There are so many places to check, but lets check the small chamber under the white plastic valve, which sits behind the brew unit, clean out the chamber of coffee grounds. If that is not the cause then, you will have to open the machine to find the leak.
Feb 17, 2010 | Saeco Vienna De Luxe Espresso Machine
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Our Vienna, Superautomatica leaks water from underneath
your problem may be in the watertank. I had that problem, and found out, the metalfeder fastened so it stayed open, after making a cup of espresso.
Nov 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Resevoir leaking on Saeco Trevi(like Vienna)
There are no screw to be removed, you have to take off the plastic ring in the water inlet. Take a screw driver and set it between the chassis and the water inlet.
Hope this will help you.
/Mirran
Aug 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Contact Saeco USA and see where they have a local service for Saeco.
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Visit the Web: www.saeco-usa.com
/Mirran
Aug 17, 2008 | Saeco Vienna De Luxe Espresso Machine
you have to replace the gasket in your water inlet, if you look where the inlet is you will see there are a little gap between the chassis and the inlet.
Take a screwdriver and bend up the plastic, you will now see the gasket.
The gasket have spare part number: 145842900
/Mirran
Aug 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO TREVI NO HOT WATER
It would be cheaper to check the thermostat and heating element first and the wiring continuity, although I am not sure if you can find the replacement parts. If you can't, then it looks like you have no choice but to replace the entire assembly.
May 19, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
229 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
