Question about Dell Dimension 2350 PC Desktop
My Dell Dimension 2350 won't fully boot up. I have Windows XP. It gets past the log in screen and the icons come up, but it freezes up at that point. I am also getting an error message at the log in screen that says "ViewMgr has encountered a problem and must close"
  • 1 more comment
  • ccshasta Mar 05, 2009
    Thanks for the help. I can't seem to even get my Start menu to open to remove that program or do anything. Any ideas for getting my computer to stop freezing up once the icons appear?
    Okay, I was successful in stating up the computer in safe mode. Thanks for that advice. I removed some programs from the start menu including View Mgr.
    However, I am still getting an application error message saying viewpoint services.exe reached a Breakpoint at x location. I am also now getting an application error thats says wmiprsve.exe cannot be read at x location. I just recently got an error message the WMI was not functioning properly and needed to close.
    Am I getting closer to or farther away from getting this thing fixed. It still won't boot up fully after I restart in normal mode.
  • Michael Thomas
    Michael Thomas May 11, 2010
    Hi there
    you can boot into safe mode just as soon as xp shows up hit the f8 key and once into sae mode you can uninstall the aim manager and any other aim programs not needed and then simply reboot the computer the reason i say safe mode is that it will try to reinstall again if you try to do this under the normal boot method
    best of luck mike
    Scholar:
  • 67 Answers
ViewMgr is related to AIM/AOL installs. It is not needed and from what I read, most find it to be a form of Malware of sorts as it opens a listening port on a specific port. Find it in your Add Remove programs and remove it.
Also, if interested, there is an alteration of AIM available from the website below which will allow you to download and install AIM and the program will remove all of the spyware-like software. It's called Aim Ad Hack and I highly recommend it over the traditional AIM.
http://www.aimadhack.net/
Posted on Mar 05, 2009
  • Matt H
    Matt H Mar 05, 2009
    Reboot the PC in Safe Mode. To do this, follow the steps below:
    1. Reboot the PC and before the Windows logo appears, tap the F8 key over and over about once a second until a menu is displayed.
    2. Select the option for Safe Mode.
    3. Log into your PC using your user account and try to remove the applications this way.
    Couple of things to note:
    • Safe Mode loads Windows with minimal programs and drivers running. It will have a large resolution and some things may not be able to be displayed with the low resolution.
    • Upon entering your account, you'll receive a prompt about loading Windows with Safe Mode and it'll prompt you with a "Yes" or "No" button, you'll want to choose "Yes" as this will keep you in Safe Mode.
    • Some programs do not allow you to remove them in Safe Mode. While you mostly encounter this problem when uninstalling large programs like Anti-Virus and similar programs, I don't believe you'll have problems removing this View Manager program.
    While you're in Safe Mode, you'll probably want to take a look at your start up programs list. You can see this list by going to:
    1. Start -> Run -> typing "msconfig" (without quotes)
    2. Click the Startup tab
    3. Look for programs that don't need to be opened at start up such as:
    • Adobe Products
    • Messenger Clients
    • RealPlayer, QuickTime, etc. type players
    One thing to note is you're going to notice a lot of things checked in the Startup tab. Expand the "Startup Item" and "Command" columns to see the full name of the program running and where that program or item is located. Things that start with "Nv" are generally related to Nvidia Graphics drivers. Same with things that mention ATI. When in doubt, leave it checked however, if you have things such as Nero installed, it doesn't need to run at start up. Rule of thumb, if its a program you can open normally, it probably doesn't need to run anything at start up to operate successfully.
    If you happen to uncheck something that turns out is needed or you notice issues with programs, you might try to see if a start up item was unchecked. You can't damage the PC by unchecking these start up items, you can just disable programs and such so it can always be undone.
    The "msconfig" screen can be opened when booting into Windows normally but would need to be restarted if anything is changed.
  • Matt H
    Matt H Mar 06, 2009
    From the research I've done, it looks like "wmiprsve.exe" is a legit Microsoft program used for some such junk. It also states, however, that a couple viruses out there replace this with a version of themselves. It causes all kinds of problems including spikes in the CPU of about 80-99% of the CPU usage for this "wmiprsve.exe" program. On top of that, it can cause random services to "fail".
    I think this might be your problem. There is a way you can scan for viruses while being booted into Safe Mode. I'll explain how:
    1. Reboot your PC into Safe Mode as I pointed out how to above. This time, however, boot it into Safe Mode with Networking. This will let you have internet access while in Safe Mode.
    2. Log in as normal and hit yes to stay in Safe Mode.
    3. Open your browser and go to www.ewido.net
    4. On the right side you'll see "Free online spyware scanner -> Here". Click that.
    5. Follow the prompts and install the ActiveX control it asks you to install.
    6. Proceed to scan all your drives and remove the bad stuff it finds.
    Hopefully when you reboot your PC normally, it will have found and removed some harmful things from your PC allowing you to boot normally and remove the View Manager program as wanted.
After a virus infected my Dell dimension 2350 (XP), I replaced the hard drive with one running Windows 7. After increasing my RAM, I still have some serious resolution problems on my Samsung 172N moni
Hey Tim,.
Once you installed Windows 7 onto the hard drive you would need to have installed the drivers. The one driver that is needed for resolution is the video card.You can right click on the desktop and then choose screen ressolution to see if you can change the resolution. Unfortunately, Dell does not have any Windows 7 drivers for the Dimension 2350 system.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 31, 2013 | Dell Dimension 2400 PC Desktop
Windows will not boot past the blue windows xp screen
You could try to restore to an earlier version of your system. This link will explain how to do that.
Mar 01, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension wont boot up to windows..
System restore:
To use System Restore to restore Windows XP to a previous state, follow these steps:
  • Log on to Windows as an administrator.
  • Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  • On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  • On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  • Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  • On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  • Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page.
If you successfully restored your computer to a previous state, and the computer performs as expected, you are finished.
Use asystem utility tool like RegInOut to fix corrupt registry and windows files.
For Restoring in Windows 7:
http://windows.microsoft.com/en-US/windows7/why-is-my-screen-black-when-i-start-windows-7
Hope it works for you.
Jan 04, 2012 | Dell Dimension 4600 PC Desktop
How to get a wireless network connection icon in a dell dimension 2350 with windows xp service pack 3
What do you mean by getting the icon? Do you mean the icon which is usually down near the clock? It this is the issue Control Panel > Network Connections and you should see the icon there > right click > properties> tick the box ''show icon in notification area''
Jul 23, 2010 | Dell Dimension 2350 PC Desktop
I need the usb controller driver for the dell dimension 2350 know where i can find it? thanks
The USB controller driver for Windows XP is a Native XP driver. If you have a problem with it, boot to the safe mode, go to device manager, remove the controller from list, make sure all USB devices are disconnected (Keyboard and Mouse excepted) reboot and let the controller re-detect.
If that doesn't work, then try a repair install of XP
Oct 21, 2009 | Dell Dimension 2350 PC Desktop
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Mar 11, 2009 | Dell Dimension 2350 PC Desktop
No sound on my dell dimension 2350 pc desktop
Go to this Dell link and download the Audio driver:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
1,019 people viewed this question
Alun Cox
