Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Sounds like your bearings are going bad. You can pull it apart and match them up at a bearing house or online. The manufacturer only sells the outer drum assembly with the bearings. $$$
I have more information if you are interested. Most front loader machines are very similar. There are several internet blogs about bearing replacement.
Make sure you buy the -2rs bearings. The main number can be something like 6307 but make sure you buy 6307-2rs. The -2rs bearings are sealed. The -2z bearings are only shielded. Not as good for water applications.
Posted on Mar 05, 2009
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Nov 18, 2017 | Washing Machines
Dec 03, 2015 | Washing Machines
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Sep 10, 2009 | Whirlpool Washing Machines
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Jun 03, 2009 | Whirlpool Washing Machines
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
May 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Apr 11, 2008 | Washing Machines
Jan 13, 2008 | Danby DWM99W Top Load Washer
184 people viewed this question
