Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore eilite oasis
Washing machine gave an error code when I was washing some jeans (UL) was the code, and it has a half tub of water in and and will not do anything now, the buttons are will not do anything, I drained the water and took out the clothes and unplugged it and it will still not do anything????
  • terrismouse Mar 06, 2009
    I had to take the back off of the washing machine and remove the hose, my brother in law had the same thing happen to his...only he had a sock stuck in the hose. He however had to pay a repairman $200.00. I did not have anything stuck in the hose but when we put it back together it must of reset something and it is now working again.
    Novelist:
  • 126 Answers
UL stands for an unbalance load where one side the tub is heavier than the other side.
when the code is displayed, it automatically unlocks the lid so you can go in and reposition the clothes to try and balance it. once you are done, simply press the start button again and it should continue again where it left off. if you push the stop button, it will drain the water and assume the cycle is complete.
unplugging it and replugging it in should allow you to do other wash cycles. press power and you should be able to select wash cycles.
if you still have no control, make sure you still have power at the outlet by plugging in a lamp and turning it on. if no power, find the GFI outlet that controls that outlet and reset it. if not on a GFI outlet, then check the circuit breaker panel for a popped breaker. reset it and power should now be restored.
Posted on Mar 06, 2009
  • joe Mar 07, 2009
    glad you are back in operation. just make sure the hose isn't getting pinched restricting water flow.
Kenmore elite oasis washer will fill with water and skip the wash cycle. It will spin and empty then turn off. we have seen the code UL what can be done to fix this?
UL=Ultra Level of water?
usually its just foam in sensor tube,as prior using too much or wrong type of detergent(for hand wash,or else). Do few cycles with just and only water,or open machine and blow tubes to level "sensor".
Jan 24, 2015 | Kenmore Washing Machines
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
What does the message ul mean?
The UL code means a unbalanced load,sometimes it can as easy as leveling the washer,or a odd load such a towels all being on one side of tub and thinner less water retaining sheets being on the other side.
Gene
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My oasis he is not a see through top but i keep getting the ul message and when it goes through the spin cycle it sounds like ajet engine. iS THERE A SENSOR THAT NEEDS REPLACED.Sears wants 129.00 to just...
UL is unbalance load. uL is displayed when the machine/motor control detects an
off-balance load, and is steady on while the washer runs a
mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the
load.If the mini-cycle is unsuccessful, uL will flash until the door
lid is opened, allowing the customer to view and
redistribute the load. Page 57 shows the suspension
rod removal to get the tub out. These rods (4) hold the tub in place. Sorry I do not have an oasis manual but this Bravos manual will give you an Idea. One of those rods could be worn to the point it is throwing the the whole tub off. If a rod is broken then the tub could be pressing against the base and binding the motor, causing that noise. You gonna have to check and see.
Nov 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In the last 10 minute wash cycle the tub shakes while spinning and the code UL appears.
mine does the same thing, looking for a solution. thinking about tearing it down tommorrow. just wanted some ideas where to start before i did
Aug 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washing machine is giving me a UL code with every wash now. Do I have to call for service or can I fix it myself?
See the following Whirlpool Service Manual for their Cabrio washer which is the same as the Sears Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
You may get an idea of the (UL Unbalanced Load) problem and solutions.
Mar 30, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
225 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
