Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Unable to get memory card in slot!
Removed memory card and now the small black release button is depressed continually and will not allow card to be put back in slot.
  • jfredin May 11, 2010
    Have you tried turning the card around, a memory card facing the wrong direction will do the same thing. I believe the card manufacturer's logo should face the back of the camera on that model.
    Novelist:
  • 155 Answers
Service manual here, parts catalog, technical info and more. Scroll to bottom of page for download link.
Posted on Mar 25, 2009
Is there an easy way to put the blade in a scorpion saw
Here is a link to the manual for your saw.
https://www.manualslib.com/manual/17171/Black-And-Decker-Ks629-638se.html?page=7#manual
Place the blade with the
tooth protector fitted
over the location pin. The
blade teeth should be
facing the handle.
Rotate the blade through
90 until it is fully located
in the slot and the
location pin is in the
locked position.
To ensure the blade is
securely fitted try to
remove without pressing
the blade release button.
Remove the tooth
protector, your saw is
now ready for use.
Note: If you are unable to fit the blade, check if the
location pin is in the correct position as shown
below. If it is not, keep the blade release button
depressed and use a screwdriver to turn the location
pin into the correct position
Feb 13, 2017 | Blade Saws
Wheel is locked up will not engage shifter move from Park to drive
1 Set the emergency brake.
2 Insert key into the ignition and turn the ignition switch to the "ON" or "RUN" position. It is not necessary to start the engine.
3 Locate the shift lock override slot located on the shifter console near the shifter lever. Normally, the slot is plugged with a small plastic cap. Remove the cap.
4 Insert a small screwdriver, nail file, key or similarly shaped object into the override slot, push down and hold
5 While continuing to hold down the shift override mechanism, depress the brake pedal.
6 Now, grasp the shifter, push in the release button located on the shifter as you normally do and then move the shifter to the desired gear. If you've completed these steps with the engine off, move the shifter to the Neutral position to start the engine.
Dont know if this helps
Oct 23, 2016 | Cars & Trucks
Why does it get stuck in park
Chris: According to MyAutomaticTransmission.com: "Shifter Lever
Recognizing that you might one day find yourself in such a predicament, vehicle manufacturers incorporated a quick and easy method for manually releasing a shifter stuck in Park. Follow these 4 simple steps.
1. Set the emergency brake.
2. Locate the shifter lock override slot located on the shifter console near the shifter lever. Normally, the slot is plugged with a small plastic cap.
3. Remove the plastic cap covering the override slot and insert a key, nail file or similarly shaped object into the slot and push down.
4. While pushing down, depress the brake pedal, grab the shifter and push in the shifter lock button located on the shifter as you normally do and then move the shifter to the Neutral position. With the brake pedal still depressed, start the engine with the shifter in the Neutral position.
NOTE: If the shifter lever will still not move, repeat the process making sure to press down firmly on the locking mechanism and the brake pedal simultaneously as you attempt to move the shifter lever.
NOTE: Continuing to drive your vehicle in this condition will not cause any additional damage. You will just have to use this procedure to release the shifter each time you attempt to move the shifter out of the Park position." I hope this helps you!
May 28, 2015 | Cars & Trucks
Green light on camera back to the right of the 'delete' button continually flashes on-off about 1 second intervals as soon as battery is inserted as long as CF card is in place. Switching camera ON...
I would start by looking into the memory card slot to see if you have a bent pin. You may need a small light and a magnifying glass to see them.
If the pins are okay, then you can try a reset by holding down the BKT and metering buttons together for 2 seconds. The metering button is on the left, behind the off/on/release.
Thirdly, you can try a firmware update on the camera which can be found here:
NikonTech.com
Jan 07, 2010 | Nikon D70s Digital Camera with 18-200mm...
I have a Digital Rebel 40 D camera less than 1 year old and I removed the memory card and I cannot get it to go back into the slot. The eject button is still depressed after I depressed it to eject the...
im no expert, but i would use a flashlight to look inside the memory card holder and see if anythings messed up, and maybe jiggle the eject button a bit, and just maybe the button doesnt come up again until you push in the memory card. give it a little push they arent too terribly delicate. but make sure you are putting in the right direction. hope this helps
Sep 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Removing the Memory Card Drive
If you can see the card, try using a hair tweezer to pull out the card.
Feb 01, 2009 | Acer TravelMate 4320 Notebook
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
