Question about Yamaha HTR-5830 Receiver
Yamaha HTR-5830 Video shut down.
I have a Yamaha Receiver, HTR-5830. It works fine till I try to watch a DVD. At no set interval, the receiver will shut down the video, the sound still comes through. I turn the receiver off then back on, and the video is back, but then it will cycle through this again. I have tried to discover the trigger for this, but nothing is consistently causing this. It did start doing this with my X-Box too, but not all the time like its doing with the DVD player. Ideas? Its not heat.
  • 814 Answers
You have having a problem with the video amp clipping the signal after it get hot. You have one way to try to temporarily solve this problem. Try putting more air flow over your receiver and cooling down the temperature inside the receiver and see if the video amplifier starts working correctly. If it does then you must put a fan on it somewhere that will keep the air flowing so the video amplifier is not allow to overheat. If this does not solve the problem, then you will need to have the amplifier replaced for it to work correctly. If the unit is under warranty then call this number 1-800-492-6242 to locate a service center in your area. Call them for help with your problem. You can also try looking on the website. Put in you model number and check in the frequently asked questions and troubleshooting sections for people who have had similar problems with this unit and see if they printed a solution for the problem. I hope this helps you with your problem.
Posted on May 18, 2009
What gauge speaker wire does a yamaha HTR-5830 use?
I dont think you can get much larger than 12 gauge wire into the speaker terminals
Feb 28, 2013 | Yamaha HTR-5830 Receiver
Can I hook up wireless speakers to Yamaha HTR-5830?
there are wireless kits available, and most all yamahas have pre-amp outputs for all the channels
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
I am trying to hook up my Yamaha Universal Dock YDS-11 for my iPod touch into my Yamaha HTR 5830 Amp but there is not where to plug it into. Do I need another type of cables to do this.
Hi, I'm afraid that your receiver doesn't support YDS-11. You can check it at yamaha site. This dock uses special cable and special connector on the receiver (which yours doesn't have).
So the only way to connect your iPod to receiver is via analog audio output (jack connector on the iPod).
Jan 29, 2010 | Yamaha HTR-5830 Receiver
Yamaha HTR 5830 sound and no pic? I get sound in both DVD and TV?CBL modes but no picture.
make sure that the yellow video jack is on the tv out on the surround unit and is plugged into the video jack on the tv. You may have to change the input on your tv to Video1 or Video2 to get the pic to come in
Jun 07, 2009 | Yamaha HTR-5830 Receiver
Yamaha 5.1 says Check SP Cable and shuts down - has been fine.
It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
Mar 22, 2009 | Yamaha HTR-6030 Receiver
Yamaha HTR5830 shuts down when any front panel button is pushed
You are having a component failure problem in the switching circuit. This unit should be taken in for service. Since it is going into the protection mode on any switch operation the failure is serious and needs to be repaired before it causes more damage to the receiver.You can call this number to find a Yamaha service center near you. 1-800-492-6242. You can also go to the website. go to the support section and put in the model number of your receiver and check out the frequently asked questions and troubleshooting sections to see if someone else has had this problem and had a repair solution printed. I hope this helps you with your problem
Jan 26, 2009 | Yamaha HTR-5830 Receiver
Component selection won't work
try to clean the connection checked the wire also if not cut...
Jun 06, 2008 | Yamaha HTR-5830 Receiver
dvd and dish tv optical inputs from both dvd and tv if tv has opticl out or give optical out from hd receiver. or rc pins from hd or tv to dtv/cable input of yamaha
Jan 02, 2008 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 Receiver Logo
163 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
