Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
Nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
THE SCREEN IS ON BUT DONT SEE ANYTHING THE LIGHT IS AMBER ALSO
  • glenn hoffman
    glenn hoffman May 11, 2010
    hi, did you just add this monitor 2 your system, or the one you have been using, and this started doing this?
    President:
  • 814 Answers
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem
Posted on May 24, 2009
Talked to factory today 06-01-12 This model the NEC LCD V1700v was first manufactured in Nov. 1999. As stated by factory after 12 years they no longer service or have parts to repair after Nov. 2011. GOOD LUCK
Posted on Jun 01, 2012
Cant get monitor to turn on
try another monitor -
if it works - go into monitors and remove the drivers.
Re-install the monitor you are asking about.
If it doesn't work -- it has a problem - if it is LCD - you can get a new one or a good used one a lot cheaper then trying to fix the old one.
Best of it.
Rice
Mar 21, 2010 | HP Pavilion F1523 15" LCD Monitor
My monitor keeps shuttinhg off how do I fix it
Common problem for E172/173 are shorted out inverter transformers driver transistors (4) C5706/5707 in the inverter circuits.
Jan 28, 2010 | Dell E173FP 17" LCD Monitor
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
852 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
