Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D
Lost password I have an Acer Aspire M1100 desktop, I can't get into my user login, I can't remember the password? Is there a way to bypass the password?
    Problem Solver:
  • 13 Answers
Last week , I was confronted with the password problem. Eventually ,
I solved my problem with the help of windows password Reset 6.0 on the recommendation of my friend. It's great!
http://www.resetwindowspassword.com
Posted on Jun 29, 2009
    Guru:
  • 108 Answers
※.Login to a computer that can link to Internet. Download Windows Password Unlocker 4.0 and decompress it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD.
※. Get out the newly created CD and insert it to the locked computer.
※. re-booted the locked computer and then followed the process of instructions. Just a few steps, the old password was removed.'''
※. Setting new password:
Step one: Open the "Control Panel"
Step two: Click the "User Account "
Step three: Select the account you wanna to set a new password.
Step four: Click "changing Account " and "set up password", then fill out the form as listed. Click "Create Password".
Thus, you have a personal login ID and Password, any one has no right to login to your computer with out this info.
Posted on May 18, 2009
    Scholar:
  • 135 Answers
Disclaimer: Following information should be used only if its your system and you have forgotten account password. Don't use this information to access a system which is not yours without permission.
Many times we face this problem when we or our friends forget Windows XP password and can't log in Windows. So here I'm posting a few methods / utilities which can be used to recover Windows password:
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2nd Method:
Windows XP and further versions also provide another method to recover forgotten password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
How to create and use a password reset disk for a computer in a domain in Windows XP
How to Log On to Windows XP If You Forget Your Password or Your Password Expires
3rd Method:
If the above mentioned tricks don't work, then try following trick which is actually a loophole in Windows XP Setup and a big security hole:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progressbar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press <Shift>+F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press <Enter>.
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
4th Method:
There are many 3rd party utilities which claim to recover forgotten Windows password:
Windows Geeks Lost Forgotten Password Service:
Windows Geeks have a program that works instantly to remove any lost or forgotten password. With this program you can get back in very quickly:
Emergency Boot CD:
EBCD is a bootable CD, intended for system recovery in the case of software or hardware faults. It is able to create backup copies of normally working system and restore system to saved state. It contains the best system software ever created, properly compiled and configured for the maximum efficient use.
You may download image builder utility which creates image of bootable CD-ROM (.ISO file), plus basic set of system tools. When the image is ready, write it to CD-R or CD-RW, and then everytime you'll need convenient and powerful system tools they'll be just at hand.
It is easy to customize the disk for your needs. You can include to CD any program you like, or remake the structure of CD completely. All you need is to change a few lines in configuration XML files.
Download Link
Offline NT Password & Registry Editor:
This is a utility to reset the password of any user that has a valid (local) account on your NT system. You do not need to know the old password to set a new one. It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. It'll detect and offer to unlock locked or disabled out user accounts. It is also an almost fully functional registry editor.
Download Link
Windows XP Login Recovery:
Login Recovery is a service to reveal user names and recover passwords for Windows NT, 2000, XP, 2003 and Vista. As long as you have physical access to the computer, your passwords can be recovered.
Download Link
Ultimate Boot CD (UBCD): [Thanks to Rakesh for recommending]
Ultimate Boot CD runs independently of any operating system. It will boot from any Intel-compatible machine, regardless of whether DOS/Windows/Linux/BeOS is installed on the machine. However, you do need an operating system and a ISO-capable CD writer software to create the Ultimate Boot CD from the downloaded ISO image file.
Download Link
5th Method:
If all fails, then simply reinstall Windows and create new accounts. To recover lost data, you can use Data recovery tools available on net but the chances will be very low to get data back.
That's all I can suggest. Thanks for using FixYa and please rate my reply thanks.
Mike.
Posted on Mar 05, 2009
  • 52 Answers
This wont be easy. But you will need to download winternals 2005. A.k.a ERD Commander. You need to download this program. vuse.com and than go to http://thepiratebay.org/torrent/3365621/ERD.Commander.2005 and burn to cd-r. put the disk in restart the computer. boot into it. go to start, in the program, look for something to do with password changer. And you can change it from there.
2 Suggested Answers
ubelong2matt
  • 67 Answers
SOURCE: Acer Aspire M1100 Desktop - lost password, can't
If you're having trouble logging into Windows, you can attempt to use the Administrator account to edit/remove the password of the user login. The Administrator account is hidden by default while in normal mode. You'll need to boot the PC into Safe Mode and login as the Administrator account. Follow the below steps:
  1. Reboot the PC and before the Windows boot screen appears, tap the F8 key about once per second.
  2. Eventually you'll be faced with a screen asking you how you want to boot Windows. Select Safe Mode.
  3. You will see some dll, sys, and com files scrolling down your screen, this is normal. Eventually the PC will boot up and you'll have a login screen with your User Account(s) and a new account, Administrator. Select Administrator.
  4. As long as you haven't, in the past, altered the password for the Administrator account, you should be able to simply click this account and have it log you in. If it requests a password, you might try "password" (without quotes) for the password.
  5. Once in, Navigate to Start -> Control Panel -> User Accounts
  6. Select the User Login information that you're not able to log into and remove the password for the account or change it something you know.
You can now reboot the PC normally and be able to log into this account without a password or with the password you created.
Lostpassword acer aspire oned270-1401
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 03, 2012 | Acer Aspire One D270-1401 black Netbook
Tip
Lost Acer Windows 7 Logon Password?
The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Most of them intall Windows 7 Operation System. As you know, a logon password should be created to protect your Windows 7 user account. Sometimes, you <b><a href="http://www.windowspasswordsrecovery.com/forgot-windows-7-password.htm">lost Windows 7 logon password</a></b>, how to reset it on your Aspire laptop? E.g. <b>Acer Aspire One</b><a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/acer-aspire-reset-windows7-logon-password-big.jpg"><img src="acer-aspire-reset-windows7-logon-password.jpg" /></a> <br /> <b>Notes:</b> <br /> <b>1.</b> If you don't have created a password on Acer netbook, you may be insterested in this tutorial: " <a href="http://www.windowspasswordsrecovery.com/create-a-windows-7-logon-password.htm">How to Create A Windows 7 Logon Password?</a>"<br /> <b>2.</b> If you forgot Windows 7 User password, you have 2 methods to retrieve it. One is below steps, another is this guide: " <a href="http://www.windowspasswordsrecovery.com/reset-windows-7-password.htm">Reset Windows 7 Password With a Password Reset disk that was created before you forgot Password</a> "<br /> About Acer Aspire Aspire is a series of personal computers by Acer Inc. aimed at the casual household user or for small business use. The Aspire series covers both desktop computers and laptops. Acer developed the series in order to cover from essentials to high performances.<br /> How to Reset Windows 7 Password on Acer Aspire? Just follow below steps to recover your Acer PC password, it will only take your few minutes.<br /> <b>1.</b> Login another computer that you have access, download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Pro_Trial.exe"><b>Windows Password Recovery Tool Professional</b></a>, install and run it.<br /> <b>2.</b> Burn a Aspire laptop password reset disk, you can use CD/DVD or USB Flash Drive. I recommend USB if the locked Aspire laptop supports it.<br /> <b>3.</b> Connect the password reset disk with the locked Acer computer, Press "Del" while the computer just start, then <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">go to bios setting to boot computer from the USB Flash Drive</a>, reboot the computer to load the program. <br /> <b>4.</b> Select the user account which you lost itslogon password, click "reset" button to begin resetting password.<br /> <b>5.</b> A message box will pop up, just click "Yes", then the user's password will be hacked.<br /> <b>6.</b> Disconnect the password reset disk, and reboot Acer PC. You will login Windows 7 without password.<br /> Screenshots on resetting Aspire Computer Password <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/burn-aspire-laptop-password-reset-disk-big.png"><img src="burn-aspire-laptop-password-reset-disk.png" /></a> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/reset-lost-acer-windows7-password-big.png"><img src="reset-lost-acer-windows7-password.png" /></a><br /> Finally <b>Acer Windows 7 Password Recovery</b> is not a difficult thing, you don't need to become a expert. Above experiment was carried out under Windows 7, but this tool also supports Windows XP, Vista, 2008, 2003, 2000.<br /> Tips: <b>1.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a Aspire Password Reset disk</a></b> before your lost Windows 7 Account password.<br /> <b>2.</b> Keep in mind that this software can be only used on your own computer, never try to use it to hack other person's login password without permission. Otherwise, you will be caught by police.<br />
on May 23, 2011 | Computers & Internet
Forgot password need a reset disk help to bypass it
Cant we just take out the battery at the motherboard to reset the BIOS password in easy way?
Dec 11, 2011 | Acer Aspire M1100-B1300A Refurbished AMD...
Forgot password do not have reset disk to main account
Go to microsoft website and download ERD (error rescue disk) for the operating system that you are using. Then write the image to a disk using Nero or any burning software. Then boot you computer from the cd. Then you will go to the Adminstrative Tools and go to locksmith then its going to give you an option to reset your password. Then you are going to use the newly created password to login.
How do i change my acer login password
Lost Acer Windows 7 Logon Password? ' How to reset Acer Aspire One password if you don't know it?
  • The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Sometimes, you lost Windows 7 logon password, how to reset it on your Aspire laptop?
May 14, 2011 | HP Mini 1000 Netbook
Got secondhand acer aspire x3200cannot log on ,asking for password from former ownwer,can i bypass this
It is possible to bypass it if its just the User's password but not the Administrator's Password
on the Logon Screen, Press CTRL+ALT+DEL keys and another Logon Dialog Box will appear, type administrator in the Username Field and press enter without entry any password. You will be logged on if there is no Administrator's Password then Go to Control Panel => User Account, Select the User and unset the password.
Thanks
Oct 24, 2009 | Acer Aspire X3200 PC Desktop
Acer Aspire M1100 Desktop - lost password, can't login in User Login. Is there a way to bypass the password?
Mar 05, 2009 | Acer Aspire™ T180 PC Desktop
I want to restore my acer aspire m1100 pc back to factory settings but it says i need a password to do that
To be honest, unless when you got the pc it came with an instruction manual and had the code in there, you will have to contact Acer support to get the code.
I once had a Acer Aspire 3680 and i had the same problem, so i called Acer support and they had the password so i could reinstal the operating system.
Here is there contact page:
http://support.acer-euro.com/emea.html
Dec 26, 2008 | Acer Aspire M1100-U1402A Refurbished AMD...
Keyboard and Mouse on Acer Aspire M1100 not functioning
may be you swaped the keyboard and mouse jacks. check them.
Nov 27, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
553 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
