I replaced the motherboard in my presario 1245. It boots up and runs find until it gets too hot. I replaced the fan with a new one still doesn't run.
  • d_rudrow Mar 06, 2009
    My question was for a Compaq laptop 1245 computer. I installed an motherboard in it last week and the computer boots up and runs just fine, until it gets too hot. The fan isn't running. What is the problem?
  • d_rudrow Mar 07, 2009
    I get a dailog box stateing Check sum bad.
    While intialing device IOS PC STATS.com
    0028:C0005338 in VXD VMM (01) + 0004338
    Is there a VXD file that is causing the problem?
  • 916 Answers
You say you replaced the fan, But did you also replace the heatsink? If not please check that
Posted on Mar 07, 2009
  • 19,396 Answers
If you are 100% sure that the fan is OK , that the fan wiring is OK , and the fan is not starting when CPU gets over the critical temperature, then you have a faulty motherboard.
What happens is that the motherboard has either a defective temp sensor, or there is a broblem on motherboard cooling system socket.
To test the socket you just test that there is voltage in it .
To test the thermic sensor you connect a couple of different fans that you know are working to the motherboard, if they do not start, then the sensor is bad.
Motherboard are considered not serviceable at component level, if you have this kind of fault, then replace the motherboard.
The problem is however quite unusual , I have seen this happening (fan not starting up because of faulty MB) only a couple of times in my career.
Ensure first that you have not broken cooling fan contacts on wiring or connector, and that the fan is starting properly.
Also ensure you have used coolant paste between CPU surface and cooling system.
If windows start Download SpeedFan
to test your CPU temp.
Do not forget to rate the solution .
Many thanks.
Posted on Mar 06, 2009
  • 13,433 Answers
As you have replaced the motherboard I don't see why the fan wouldn't run. Is it wired correctly? 3 pins I assume, check that they are connected properly.
So you have replaced both, the motherboard and the fan?
If everything is wired properly the fan is not getting power from the motherboard. a work around would be to get power to the fan elsewhere, for example from usb port. USB gives +5, usb pinout
http://pinouts.ru/Slots/USB_pinout.shtml
other possibility would be to wire the fan to the motherboard so that it gets the required voltage. Thats a bit more advanced modification and if you decide to do such modification note that it will void any warranty you have and you will need to find a proper source for the voltage and then wire the ground to a general ground that goes to the battery.
That is possibly dangerious modification, maybe directly to battery contacts.
try that at your own risk.
  • 523 Answers
IT happen with me , its the fan problem again, make sure when you put the heatsink on top the cpu, this fan should be hooked well and locked well, if you its not hooked on top the cpu you well it causes this problem. also make sure that you putted the thermal glue on top of cpu before you connected the heat sink, also make sure that the heat sink fan works fine.
Best Regards
  • Kyocera HP Expert Mar 06, 2009
    If it gets too hot and shut down this is only cause when heat sink is not connected well, so the cpu shut down your computer in order not to be crached, but if i check it and its not hot , this means there is lack of power comes to your board, and this means the power supply is not giving enough current, so check your board how much dc it needs, or check coz some boards need another dc connector in order to boat up.
    Hope for you the best
  • 679 Answers
If the first one burt out, it would make sense that there is a cooling issue. It would make sense to see why it got that hot before continuing, you may have some dead or dying cooling fans. Have you checked to see if all the fans work and the processor fan and heatsink are working.Don't keep messing with it or you will fry the processor and the ram, aside from the board.
Posted on Mar 05, 2009
  • 1,800 Answers
Check the CPU fan.
check bios CPU speed set it automatic.
set the default settings in bios.
if not work decrease CPU speed from Bios.
also upgarde RAM memory.
    Brigadier General:
  • 8,619 Answers
Hi!
Have you overclocked your motherboard? Is the heat sink connected fine?
Please go to bios settings and see the fan settings.
  • 583 Answers
Replace the power supply.many a times a faulty power supply causes this problem of going off after some time.
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
The female plug in my Compaq Presario (for AC adapter) is broken from the motherboard. Computer still runs, since the battery is about 90% charged. Cab this battery (it has 5 female terminals) be...
i cannot think of a commercial product designed for this. I believe that you either may need to send it in for repairs, or if the pin inside the female end is bent, try bending it back. BE CAREFUL.
Feb 09, 2011 | Compaq Presario 1245 Laptop Charger...
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario fan is not functioning. It is - fan is plugged into the motherboard but the fan will not run - causing my laptop to overheat - I cannot find a fan controlling software that is compatible...
sounds like a burnt up fan so you might just want to take it to your local computer tech have them replace the fan and put some new cpu compound in their and it will never over heat again
Aug 06, 2009 | Compaq Presario Fan
I've got a compaq presario 1245 laptop. On booting it gives me a black screen with "Error 0270 Real Time Clock Error" I can get into the Setup and boot screens (F1 & F10) but any changes (reset date/time...
hi
you will need to open your computer and look inside. if you are not sure take to a repair centre, the battery is on the motherboard, thats why you need to take really if you are going to be doing it. But i would advised to get a IT guy to do it for you. once its taken out you need to replace it with a new one.
Mar 25, 2009 | Compaq Presario 1275 Notebook
Presario will not stay on and error message appears
Sounds like your harddrive controller on the motherboard has failed.Boot into the bios and see if the harddisk is reconnised if not (which i am sure it is not) the you need a new motherboard ,sorry!
Dec 15, 2008 | Compaq Presario 700 470024-192 Notebook
you could try booting on battery instead of mains and see what happens, also could the screen be switched off ? If you have access to another monitor, you could try plugging it in to see if the video output is ok. ( some laptops have a facility to switch off the screen display for security etc )
Jan 04, 2008 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 1245 doesn't start up
Most laptops have a video connector that you can use to connect you laptop to an external monitor. connect an external monitor to your laptop and see if anythig comes up on the external monitor.Your laptop has a key to switch between it's own screen and the external monitor.When you use the external monitor ,you'll have to use this key to switch to the monitor.Your battery should'nt matter if the laptop is running on AC.Let me know what happens and we'll go from there.
Jan 02, 2008 | Compaq Presario 900 /1500 Series EVO...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
