Question about Pioneer DEH-P4700MP CD Player
How to set the clock
Need to know the steps to set the clock
    Scholar:
  • 61 Answers
Hi There
you will need to hold down the source button till the unit shuts off
once the unit is off look for a Button with a F (Function) hold this button down till the LCD display turns on it should only take a few seconds.
once the F (Function is active on LCD) press the F Button (i think its X2) till you see the clock
once your are at the flashing clock use the skip buttons on unit to switch numbers after the hr time is set press F Button again to adjust the minutes.............
when this is done press the source button to turn the unit back on and the clock should be set.....
hope this helped
Posted on Mar 05, 2009
How do I set the clock on my acurite
Press and hold the SET button. when the two dots start to flash, use the hour button to set the hour and minute button to set the minutes. more accurate steps can be given if you share the make and model of the Clock Radio
Mar 02, 2016 | Audio Players & Recorders
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
To check the current clock time or change the
display mode
Press DISP (display) repeatedly.
Each time you press the button, the
display changes as follows:
• During tuner operation:
• During CD operation:
• During power off:
The power turns on and the clock time is
shown for 5 seconds, then the power turns off.
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
I cant set the clock on my keyboard
To enter the time/date setting you must press the FN key
then to set the date/time press the F10 key.
I hope this solves your problem. If not please check the forums.
Dec 15, 2008 | Logitech Cordless Desktop MX 3000...
Car CD Player Time Settings
Click on the link below and you will get step by step guide.....
http://www.pioneerelectronics.com/PUSA/Products/Setting+your+Clock#nav
Please do not forget to rate this solution
Cheers!
Nov 03, 2008 | Pioneer DEH-P6800MP CD Player
Setting clock on car player
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
May 20, 2007 | Pioneer 50w x 4 CD/MP3/WMA/ receiver with...
Pioneer DEH-P4700MP CD Player Logo
188 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
