Question about Sansui DTV3200 32" TV
Can't get closed caption off of television - Sansui DTV3200 32" TV
  • Sansui Master
  • 520 Answers
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Posted on Mar 05, 2009
  • 75 Answers
Look in the menu for closed caption turn it off you may have to use the +or - for the volume to geterdone.
2 Suggested Answers
SOURCE: removing close caption on television
I was able to obtain a users manual online for free but I need to have a remote to remove the closed caption. Thanks for the response but I don't need to apply for an assistant plan.
Posted on May 26, 2008
No closed caption
When a television tells you that no captioning is available it is telling you that the broadcaster is not supplying closed captions. You are doing everything right, but the show you are watching is not captioned.
Nov 17, 2012 | Maxent MX5020 50 in. Plasma Television
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
How do I turn off closed caption?
Hello
From the main menu, surf though and enter the closed caption window. Here you can see options for Analogue closed caption, Digital; closed caption and Caption style to select. Here select "OFF" for both analogue closed caption and digital closed caption option.OK.
Refer to your TVs user manual. If you haven't its user manual, inform me though Fixya. Send your email ID too. OK.
Feb 14, 2011 | Hannspree XV32 32 in. LCD Television
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Closed caption
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Dec 02, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed Captioning
I it was sold In the US it HAS to have the opyion of closed caption as to the Americans with Disabilitys Act(ADA). It has to be in the manual somewhere. Contact 1-800-968-3429 Good Luck
Aug 17, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sansui DTV3200 32" TV Logo
1,094 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
