Question about Maytag PAV2300 Top Load Washer
Can't remove agitator
Could use some advice on removing the agitator PLEASE
  • Maytag Master
  • 3,361 Answers
Remove the top of the agitator and then remove the bolt inside.
Posted on Mar 05, 2009
Tearing and twisting clothes
Possible that the agitator or the bearings are worn out and so there is a gap in the play of the agitator allowing the clothes to get entangled within the agitator and causing the damage.
Please check this link for tips to remove and check the bearings:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Aug 03, 2012 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
Please read this link below first before you try to remove the agitator.
http://www.geappliances.com/search/fast/infobase/10002927.htm
This link below will tell you how to remove the Agitator on the ge washer.
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
Jul 07, 2011 | Washing Machines
How to take agitator off
If the model number is correct, the agitator is removed by following these steps:
1. Using a flat blade screwdriver, pry up on the agitator center post cap and remove.
2. Under the agitator center post cap is a 7/16" hex bolt. Using a rachet and socket, remove the bolt and washer.
3. With the bolt removed, grasp the agitator on each side of the bottom flange at the bottom of the wash tub and lift straight up.
NOTE: Detergent can often leave soap deposits under the agitator and make it diffult to remove. You may have to rock the agitator from side to side a little to break it free.
If this is NOT your model number, please post back with your correct information. if you have questions, or need additional assistance, please post back and let me know. I hope this helps you.
Oct 13, 2010 | Roper RAK2751WWH Top Load Washer
A necklace has dropped down under the agitator in my Simpson Espirit 700, how do I get it out. Thanks - ****
Hi just read your posting.Now do you still require help?If you do then pull the middle of the agitator out and shine a torch down the center.You should see a 10 mm bolt.Grab a socket set and turn the bolt anticlockwise to remove it and then lift the agitator out.Please reply on how you got on and for more advice if needed.Looking forward to your reply.
Aug 17, 2010 | Washing Machines
The bottom part of the agitator will turn, but not the top part
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears. Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid. -- click on this link directly to get the detailed instruction for replacing dog ear
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136
to remove the whole agitator check out the instructions as follows:
(1) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1, picture2.
(2) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator. also you can get the exact required parts from www.repairclinic.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 25, 2009 | Kenmore Washing Machines
There is a curtain stuck in the agitator how do i remove the curtain
Hi, Remove the cap to the agitator and there should be a 7/16" bolt. Remove the bolt and the agitator should lift out. Please let me know if this helped you at all or if I can assist you further.
Thanks
Vic
Jul 29, 2009 | Kenmore 22422 Top Load Washer
Agitator not agitating to wash cloths.
remove top of agitator remove plastic cap inside agitator housing. remove 7/16 in. bolt. lift out agitator
Jun 20, 2009 | Washing Machines
Can't remove agitator dogs from agitator
youll need to removethe agitator first, then while standing on corners of agitator pull up seperatin gthe 2 havles, dogs are right there
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag PAV2300 Top Load Washer Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
