Question about Gaggia Baby Espresso Machine
Gaggia Baby - water leaking from round the edge of main bulkhead
Water leaks from around the bulkhead when making the espresso. It seems an internal gasket may have burst due to limescale blocking the main channel - is this a fix-it-yourself problem or a return-to-maker one?
Also, we now have to turn the knob several full revolutions before we start ot get any steam from the frother. More limescale build up? We do descale, just not enough probably for a hard water area.
You need to replace the main rubber gasket within the bulkhead. due to heat and use, the gasket cracks and no longer is able to seal the brew head. a new gasket should be part of the warranty but you can purchase one and replace your self, pretty simple.
Posted on Apr 25, 2009
My Gaggia Syncrony Compact has developed some sort of leak. Every few days I notice a pool of water spreading across the countertop in our pantry and pooled under the machine. The leak might be happening...
HI
I would suspect the seal on the machine where the tank sets on the machine. There is a plastic cap that looks like a doughnut, that will pry off (there are 2 hooks, 1 on each side). The seal is under neath. If you can stick your finger in the center of the seal and lift it out it needs to be replaced. When you put the new one in, run your finger nail around the outside edge of the seal to get it to slip in or you could damage the new seal.
Oct 24, 2010 | Gaggia Syncrony Compact Coffee...
Water leak causes the main power to trip. can you
Yes it can be repaired, I would suggest getting a rebuild O-ring kit for your machine, it comes with all the gaskets and O-rings that you will need for the machine.
May 30, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Leaking water
If the machine is less than 6 months old then there could be some coffee aound the gasket use a toothbrush to clean the gasket and try again. If the same result, then the gasket needs to be replaced.
Aug 12, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
May 10, 2009 | Gaggia Titanium Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Leaking water
It sounds like the main valve is faulty. Replacements are available or you may be able to dissasemble it and replace the seal.
Hope this helps.
Sep 04, 2008 | Gaggia Baby Espresso Machine
Gaggia syncrony compact coffee machine
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Jul 22, 2008 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
925 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
