Question about Whirlpool Washing Machines
Clutch replacement on whirlpool washer lse8223e
How do i replace clutch .... some instructions
  • strawberripa Mar 05, 2009
    model #LSR8233EZ1
  • Scott Wiuff
    Scott Wiuff May 11, 2010
    Is this a direct drive top loader with the pump in the front? Look at the model number under the lid. I don't recognize the model. If it's what I think it is, it's real easy.
    Scholar:
  • 87 Answers
Below is a link that will show a little in detail. 1st take off the control panel. Use a putty knife between console and base of washer. Go to the outside corner and push in and tilt back cont panel. The remove 2 gold clips underneath that. the whole outer cabinet will then come off. The take off the outer top ring on the basket it's the one the soap drips into. It's just clipped on. Then remove the agitator. Usually to top cap pulls off and there is a bold holding the bottom agitator on the shaft. Then there is a silver nut on top that that you'll have to get off. We have a special wrench but take a screw driver and spin it off. The the whole inside basket can be pulled up and taken out. Then look at the motor and pump in the front. They are just clipped on so remove them and un-hook the motor wires and set that aside. The there are 3 screws holding the transmission to the base. I would tilt it back so you can see them and pull out the whole transmission. It'll just drop right out then you'll see the cutch. Sounds like a lot but if you refer to the pictures on the link it will help a lot. Good luck and let me know how it goes. Looks like the clutch is abot $40.00
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=Wa0fOurdi7fM+OMoEj4qWA**.shcapp3206?modelNumber=LSR8233EZ1&pop=flush
Posted on Mar 06, 2009
Washer in the las cycle do not extract the water completely in other words do not spin (hi) to extract the water
You will need to replace the "clutch band" on the washer. The clutch has become worn and will not engage completely to bring the washer up to the proper spin condition. Here is a link to the clutch kit and it comes with the complete instructions for the repair.
Feb 12, 2011 | Whirlpool LSQ9600L Top Load Washer
The agitator on my whirlpool saws800jq2 top load washer is not spinning. where is my problem? motor? clutch?
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Whirlpool Washing Machines
Agitates but won't spin
either bad clutch / brake or bad transmission
Jul 19, 2010 | Whirlpool GCAM2792LQ Top Load Washer
My macine draines the water but dont want to turn over to spin, what can the problem be?
soundsw like you have a bad clutch on your unit costs about 25 dollars problem is you would have to know how to remove and then reinstallthe entire transmission to replace the clutch heres some instructions on how to get the job done fixitnow.com/.../how-to-replace-the-clutch-in-a-whirlpool-direct-drive-top-loading-washer
hope this helps any problems write me back
Jul 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer 110 makes grinding noice only at first of spin cycle. is it the clutch?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
In order of difficulty, there are three possibilities.
1. It's possible that the Motor Coupler is worn / broken.
This is a three part plastic and rubber device that transmits power from the motor to the transmission. If it's worn and slipping you may hear the plastic pieces grinding against each other.
It's an easy repair.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=2e8e02b3755ab86d8e046bc88e9db27b
If the Coupler is worn, it's an easy and inexpensive fix.
2. It may be the clutch bands have worn.
See the following for how to remove the pump, motor and transmission. The clutch is on top of the transmission. Sears has replacement clutch bands.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to remove the drive tube and brake to change clutch bands.
If it isn't the motor coupler or clutch, it could be the "agitate cams" in the transmission.
These are plastic pieces that move the agitator drive shaft up about 1/4" when the washer goes into the spin cycle. If they are worn, you may hear a grinding noise.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See also a more detailed description from Whirlpool of how their transmissions work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
The agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams and the Whirlpool part numbers.
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
Mar 12, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore agitator clutch dog replacemant?
The followng link explans how to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the instructions and let me know if you have any questions. I hope you find this information helpful.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How to replace the gear case for whirlpool washer lsn1000kq0
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
389 people viewed this question
Dan Webster
Dan Webster
Sal De
