Question about Dell Inspiron 1300 Notebook
Dell inspiron 1300 stalls at blue welcome page?
When i started it up it looks like it's working fine then it just stalls at blue startup page when it says welcome and i cant do anything from there. I ran the express test and it didn't say anything was wrong? Do i need to reboot the computer? I've had this laptop for a while now and i don't know where the reboot disc is anymore. Where could i purchase one that would work?
  • 1 more comment
  • margaret may Mar 05, 2009
    Recently ,when I insert a cd containing data computer acknowledges it as audio not data and cannot open it.  From then on have relied on memory sticks for storing data.
    More recently computer starts up but does not log on to desktop stage.  Ctrl Alt Delete suggests I am logged on when in actual fact I am not....Only blues screen is visible.
    I am now solely dependent on desktop.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    If you've already booted then Last Known Configuration in Safe Mode will not work..(hit F8 upon starting)..go into safe mode (F8)..click start>accessories>system tools>system restore. It will restore your computer to a date prior to problems...this is not the only option for this particular situation so if that does not work let us know..
  • My reply is May 11, 2010
    Will it boot up and run in safe mode?
  • 52 Answers
It could be a hardware failure. Bad Hard drive maybe. You will have to go to the manufacturers website to get the reinstall disk. A.K.A Recovery Disk. You will have to pay. And they will send it in the mail to you. Good luck.
Posted on Mar 05, 2009
My dell inspiron freezes on the welcome page
While there are a number of possible solutions which may or may not work depending on several factors, the easiest to try is to boot to safe mode and run a system restore.
To boot to safe mode:
When you start the system, as soon as the blue dell logo goes away, tap the f8 button. This should get you to a menu from which you can choose "safe mode". It will show a bunch of writing on the screen and should eventually bring you to the login page, login as administrator.
Run system restore:
This varies depending on which version of windows you are running. In XP it is start>all programs>accessories>system tools>system restore.
Other things you can try:
Login as a different user.
Use start>run>msconfig from safe mode to disable startup items which may be causing the problem.
Consider removing recently installed software which may have caused the problem.
Scan for viruses, malware, spyware, ect.
Run diagnostics on the system by pressing f12 on the dell logo and chosing diagnostics.
The worst case scenario to fix a problem like this is reinstalling windows.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
Evreytime i startup my dell inspiron 1300, it takes at least 15 minutes to start
You probably have a lot of programs starting in the startup. Try to change the settings so that they don't start in the startup. Also try un-installing programs you no longer need. Hope that helps.
Oct 24, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Slow pc
Just delete the IE cookies and virus. Also clean all the startup item add-in and useless program End the Dell inspiron 1300 battery useless process in Task Manager. Uninstall the unnecessary programm.
May 14, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
Dell dvd not working
First thing you need to check is whether the issue happens only if you are logged in to Windows or not. For you to check if it also happens outside of Windows, insert the Windows Operating System disk (XP or Vista) then shutdown the computer. Turn it back on. As soon as you see the Dell Logo, keep on pressing F12. Then select "CD/DVD ROM" from the choices and press enter. When you see the prompt "Press any key to boot from the CD", keep on tapping the "Enter" key. If your CD/DVD drive is working fine, you should see a page that'd say "Windows is loading files". If not then the system is not detecting your drive. Then check the BIOS page. F2 on the Dell Logo. Then look for Drive Configuration. If the drive isn't there, reseat it. Physically remove the drive from the computer and put it back in. Then restart.
Please rate this if it helped.
Dec 21, 2008 | Dell Inspiron 1300 Notebook
Screen goes blank soon after switching on
Try "Safe Mode" (holding F8 key on boot and selecting "Save Mode"), then run diagnostics and an up to date (virus definitions) Anti-Virus full scan.
If Safe Mode is not accessible then you may want to consider a format and clean install by booting to your Windows (?) CD.
Sep 06, 2008 | Dell Inspiron 1300 Notebook
Dell inspiron 1300
Follow this process ---> Press and Hold CTRL + F11 by the time you see the blue line that has www.dell.com after the dell splash logo and then it would show up the symantec ghost --> choose restore then follow the rest of the affirmative prompts
Aug 09, 2008 | Dell Inspiron 1300 Notebook
Sound driver
i want you to install dell inspiron 1300 sound driver for me
Jun 28, 2008 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
113 people viewed this question
Alun Cox
