Question about Welding Tools
I can't feed wire all the way through to gun assembly. I can push wire from the gun end in farther than where the wire stops when feeding it through forward.
Try rotating the gun when pushing or it looks like ya need a new liner
Posted on Apr 16, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
I have a kende mig 105 gasless welder,but the wire isn't getting fed through on the feed wheel,tried different welding wire and also turned the wheel,tried tightening the wheel,slackening it as well,i
Here's a few things you can check:
When gun trigger is pulled, do the drive wheels turn? If they aren't, pull the trigger again; do you hear anything within the machine (contactors closing, gas solinouds opening, any clicking, etc.) that would indicate the trigger circuit is functional?
If the drive wheels are turning, but wire isn't being pushed thru the mig gun, check for proper drive roll vs. wire size. If that is correct, check gun liner for obstructions. Flux cored wire tends to stop up a wire liner fairly quickly.
Dec 21, 2014 | Welding Tools
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
The wire is slipping on the wheels and not feeding to the gun
check the tension on the spool - is it free to rotate ( but not so free it over-runs when you release the trigger)
check the tension on the drive wheels - are they turning and slipping on the wire?
Do you have the correct drive wheels for the wire size? if you're using .8 wire, you need to be using .8 drive wheels (or the .8 grooves if you have multiple grooves.
is there a kink in the liner? pull out the liner (remove the whole gun attachment, usually the liner will slide out from the end where it attaches to the welder). Blow out the liner with an airgun while you're at it as they fill up with crud.
When you reassemble the gun, slide a lenght of wire up the cord and check that you can push it all the way in freely.
Then when you rig the welder, leave the tensioner off the drive rollers, and push the wire into the gun by hand. you'll feel if there are any tight spots ( usually caused by kinks in the liner).
once you've rigged it, clamp the drive rollers shut and adjust the tension until they feed the wire smoothly. (leave the contact tip off the gun when you rig it as the tolerances are so fine that even the small flattening of the wire where you cut it will usually prevent it from feeding into the tip. Once it feeds properly, reshape the cut end of the wire and attach the tip (don't force it over the wire or you' ll just damage it)
Jul 13, 2012 | Welding Tools
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
My wire feed quit feeding wire what do i need to replace to make it work
Hi:
If your drive rollers are moving but can't push the wire all the way to the end of the gun, your problem could be the liner in your gun and/or the contact tip. Try to replace both. If your drive roller are not moving then check the trigger of the gun.
Oct 03, 2011 | Lincoln Electric LE 83180 Century...
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
My wire feed is not working. there seems to be a crimp in the line leaving the welder. what is the best fix?
If the "line" leaving the welder is the weld gun the crimp could be that the liner in the gun lead is indeed crimped. This will not allow the wife to feed from the gun.
Remove the gun from the welder and see if you can push or pull the flux wire in/out of the gun. If you cannot then remove the liner and replace it. If the crimp is too bad you may not be able to evem remove the liner.If that is the case yo may have to replace the gun. Hope this helps.
Oct 18, 2010 | Firepower Flux Core Wire Feed Welder 88...
How to replace cabin air filter. model : kia amanti 2005
On the 05 Amanti, open the glove box, take everything out, then push the box past the stops. It will drop down more and expose a wire that has spring tension on it. With one hand pull the wire a little farther out and with the other hand feed the end of the wire out of the glove box. Slowly let the wire retract - don't let it snap back. You will now see the entry into the cabin air filter. Push down on the 2 tabs and remove the faceplate. Remove the filter. Put new filter back in and reverse the above directions
Oct 06, 2010 | 2007 Kia Amanti Sedan
Wire feed not working wire feeds through the gun freely motor does not advance the wire
Does it have a feed adjuster ? its like a clamp over the wheel that applie pressure to the wire in order to push it through the line!
always deburr the line when feeding it into the tube!!
cheers rob
Jun 28, 2009 | Lincoln Welding Tools
Welding Tools Logo
88 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
