I have a speed queen front load washer that starts in the spin cycle and turns at a low speed of about 60 rpms and then shuts itself off after about 20 to 30 seconds sometimes it sound like it is going to shift into high speed but just cycles down and turns off. Model is LTS84BWH serial no. 0403014466 I cleaned out the pump and the discharge hose from debris so all water that could be pumped was. I thought that maybe all of it wasn't pump out and throwing off the balance? So it wasn't able to spin for a long period of time or at high speed.
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
