Question about HP PSC 750 All-In-One InkJet Printer
Scanning I am trying to scan pictures into my computer but when I try the scan button I get an error message telling me to shut off then retry, I've done this numerous times, it seems ever since Vista came on that is when the trouble started. I am trying to scan pics for a school reunion.
  • rosemary5120 Mar 06, 2009
    No , I figured it out and it worked
    Genius:
  • 2,120 Answers
Scanner unit has failed. It costs as much to replace it as a new printer.
Posted on Mar 06, 2009
Getting error message- paper size does not match. How do I change that?
This is a menu setting in the scanner / printer not the computer. Go through your setup menu on the Scanner/printer and you should see the settings. Also, try using the preview option and select the correct area to scan before scanning.
Nov 02, 2011 | Apple MacBook Pro Laptop Computer with...
How do I scan when I get the message "no scan options"?
You can scan from the solution center on the computer provided that the software was already
  1. look for the hp solution center icon on the main desktop screen.
  2. double-left click to open it
  3. If it's properly installed ,you should be able to see scan menu (scan document,scan picture,home,settings,etc.)
  4. scanning from solution center is an alternative way of scanning other than scanning to computer
  5. start scanning from the computer using solution center software to unveil its features.
  6. for scan to PC: if your receiving no scan options error ,update the settings from solution center
  • click HOME on solution center
  • click scan settings
  • depending on your software version click the option available to you
  • scan to setup
  • front panel button settings
  • front panel scan button settings
  • transfer all files from the left hand-side over to the right-hand side by clicking on one item then by clicking on add until all get transferred.
  • click update device
  • try scanning from printer
if issue persists i suggest you download and install scan diagnostic utility to fix scan issues. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/scan_diag/&lang=en&softwareitem=oj-90927-2
Jul 28, 2011 | HP Officejet 6500 Wireless All-in-One...
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
When I press Scan on my Brother MFC440CN, I get an error message ''Check Connection''. I just want to scan a picture to card, which I did many times without an issue.
instead of scanning using the button on the machine try it from the computer. Brother normally gives the control center program, you can find it in all programs in the brother folder. you should be able to scan from here. if not there is probably a connection problem from the printer to the computer
Mar 24, 2010 | Office Equipment & Supplies
Error message cannot find twain source and toolbox
Have you tried deleting the scanner from add/remove hardware under control panel? If not, try disconnecting it from the computer, then try deleting it, then retry the install one more time.
Aug 19, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
No scanning, no printing, no xeroxing
thanks for your answer.now the problem is even bigger.there appears a message saying Port disabled and then Cannot open device.i'll try change the USB cable to see if it helps.
Thank you again!
Sep 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Scan Problem
try using a lower resolution for your scan... also this is a known problem for windows vista what o.s. are you using?
Jul 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
No Show!
Two things you can easily check:
Ensure the issue is not caused by Electro Magnetic Interference (EMI) EMI can cause similar image quality issues. Verify that the scanner is not in the direct vicinity of the computer monitor and/or speakers. If so, relocate the scanner at least three feet away from the monitor and/or speakers and retry the scan.
Also, try this as well:
Re-home the scanning carriage The scanning carriage in the scanner may have lost the home position and needs to be reset.
  1. Shut the computer system off and then disconnect the scanner from the power source. Leave the scanner disconnected from the power source for at least one full minute.
  2. Reconnect the power and then restart the computer system.
  3. When the computer system has fully restarted, try scanning again.
Oh.. and you ARE using the power supply that came w/ the scanner aren't you?? If not, you NEED to.
Maggie B
Feb 21, 2008 | HP Scanjet 4570cxi Flatbed Scanner
Scanning pictures to my computer.
Can you provide a bit more information. What problems are you having? Are you getting error messages? Where are you trying to download from?
Oct 29, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP PSC 750 All-In-One InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
