Question about Acer Aspire 5630 Notebook
Acer laptop too dark and keyboard i have doesn't have "fn"
Ok so i own an acer laptop and my screen isn't bright at all and everyone is saying to use the "fn" key but my keyboard doesn't work so i have to use a keyboard that plugs in and it doesn't have "fn" so now what?
  • Serbob May 11, 2010
    Here's an idea... my Acer laptop battery is dead dead dead... and oddly enough the keyboard doesn't work when the battery is connected. With the battery out, and on AC the keyboard works fine. What are the odds that this is your keyboard issue?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Well I hate to be the bearer of bad news but the FN brightness option is the only option. There is no software available to brighted a screen as that is all hardware related...I guess the real answer is get your keyboard fixed..
Brighten lcd screen
OK, you are part right. The Fn key on most laptops is written in BLUE. This corresponds to the BLUE legends on various keys on the keyboard. MOST laptops have a pair of generic symbols for the screen brightness up and down . The brightness UP is a blue square (rectangle) with a large asterisk inside. The brightness DOWN is the same except it has a small asterisk inside. You will usually find these two keys as a secondary function of a function key.
Example: On my ACER netbook Fn+F6 = brightness UP and Fn+F5 = brightness DOWN
Nov 13, 2013 | Acer TravelMate Computers & Internet
Screen is very dark
Locate the Fn (Function) key on your keyboard.
It may be on the bottom left side with dark blue letters.
Locate the two "brightness" keys near the top of the keyboard.
These will be in the "F" keys, possibly if F6 and F7.
They should have little sun pictures or something similar to indicate brightness.
Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness.
Tap F7 repeatedly until you reach the desired brightness.
Fn must be held down as you continue to tap.
Hope this helps
Nov 08, 2012 | Acer Aspire One 521 532H 533 D260 NAV50...
How do I make the screen brighter on my Acer Aspire 5100 Laptop?
Try using keyboard combination Fn+right arrow. If this doesn't help right click on battery icon on taskbar, select Adjust screen brightness, then move slider for Screen Brightness to the right.
Sep 05, 2011 | Acer Aspire 5100 Notebook
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
Screen has gone very dark. Where are the brightness controls?
Hi there there is a key FN press that key as well as press Left & Right Arrow key for adjusting the screen brightness. Thanks.
Dec 03, 2010 | Acer NSK8458AN Keyboard
My acer aspire 5630 laptop has a very dull/dark viewing screen it is fully charged and on high performance, help plz. Cheers G.
check on the keyboard, lots of the keys have an extra function, normally written in blue.
Look for the two that show brightness... it the same symbol on TVs that sets brightness...
now look for the "FN" key.
press and hold the "FN" key and then press the brightness + key... this should make the display brighter...
Dec 09, 2008 | Computers & Internet
Screen is dark and needs to be brighter
look on your keyboard for the key with the 'fn' meaning function and then press the up arrow key on the keyboard. This will make the screen brighter this happens when you are on your battery to save power. You can also do it manually by accident.
Dec 04, 2008 | Acer TravelMate 4200 Notebook
Dim Screen
there is a monitor brightness that is usually a combination of Fn(lower left of keyboard) and F5..try that to see it it raises the level
May 13, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5630 screen brightness adjustment...
You press the function (Fn) key and the left/right arrows, not the Ctrl / Alt, shift buttons
Oct 26, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
134 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
