Question about HP Officejet 6310 All-In-One InkJet Printer
I have a hp 6310v on a wireless network. It
I have a hp 6310v on a wireless network. It prints from both computers on the network, but when I try to scan I get a message that says the scanner is being used by another computer and try again later. I also try scanning from the scan from on the printer and I get an error saying no scan options. Any ideas??
Refer to hp.com then on the search box type: no scan options. there is a step by step methods there that you can perform.
Posted on Mar 05, 2009
Will my hp officejet 6110 work on chromebook
Yes your hp office jet 6110 works on chrome book by following the below methods:
Method 1: Check system requirements
• Chrome book connected to the network with an active Internet connection.
• Create Google account in the latest version of chrome browser.
• The printer hardware is set up and connected Chrome book with a USB cable or wireless network.
USB connection: Make sure the cable is securely connected to the printer and to a working USB port on your Chrome book or computer.
Wireless network connection: On the printer, make sure the wireless signal is turned on and the printer is connected to your network. Make sure the printer is connected to the same network the Chrome book or computer connects to.
Method 2: Install HP Print for Chrome
1. Open the Chrome browser, and then go to the HP Print for Chrome
2. Click ADD TO CHROME.
A confirmation message displays. Adding the HP Print for Chrome app
3. In the Add "HP Print for Chrome" window, click Add app to confirm the new app.
Feb 01, 2017 | HP OfficeJet 6110 All-In-One InkJet...
HP photosmart c309 printer continues to not print or will only print the header and stops printing. How do I fix it?
Network troubleshooting
If you are encountering issues using your HP Photosmart over a network, try the following steps in the order listed:
  1. Turn off the router, product, and computer, and then turn them back on in this order: router first, then the product, and finally the computer. Sometimes, cycling the power will recover a network
    communication issue.
  2. For wireless networking issues, run the Wireless Network Test from the product control panel.
    1. Press Setup.
    2. Press the down arrow button until Network is highlighted, and then press OK.
    3. Press the down arrow button until Wireless Network Test is highlighted, and then press OK.
      The Wireless Network Test prints.
    If a problem is detected, the printed test report will include recommendations that might help solve the problem. If you need to change the network settings on your product or have never run the Wireless Setup Wizard, do so now.
    Double-click the HP Solution Center icon, click Settings, click Other Settings, select Network Toolbox, and then select the Wireless Setup Wizard link.
  3. If the previous steps do not solve the problem and you have successfully installed the HP Photosmart Software on your computer, run the Network Diagnostic tool.
NOTE: The diagnostic test might prompt you to connect a USB cable between the product and your computer. Position the product and computer near each other and have a USB cable readily accessible.
To run the Network Diagnostic tool. In the Solution Center, click Settings, click Other Settings, and then click Network
Toolbox. On the Utilities tab, click Run Network Diagnostics.If you are unable to run the Network Diagnostic tool or it does not help solve the problem, check the following sections for additional information:
  1. Make sure that the computer is connected to your network
  2. Make sure that the product is connected to your network
  3. Check to see if the firewall software is blocking communication
  4. Make sure the product is online and ready
  5. Make sure the HP Device Discovery software is running
Sep 09, 2014 | HP Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
You can now print from any computer on your network.
Jul 31, 2012 | HP Office Equipment & Supplies
What kind of ink do i need for my hp office jet 6310v all in one. i want to print color and black in white
You can find it at Office Depot. Here is the link.
http://www.officedepot.com/catalog/inkDepot.do#manufId:100686/typeId:402561/modelId:101110/
Thanks
Jan 08, 2011 | HP Officejet 6310 All-In-One InkJet...
Trying to install HP 2101nw wirelss print server but get message can't find the print server on the wirless network form this machine. I am trying to set this up stand alone , not via a router
The server maybe enabled but you need to navigate on the printer and select a wireless network you want to connect to (just like you would when you connect a computer to a wireless netowrk). Once the printer is connected to the wireless network. try it again
Nov 16, 2010 | HP 2101nw Wireless G Print Server...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
HP c7280 Stuck in print que...
Please click here and follow the instructions to clear the print queue manually.
Oct 07, 2009 | HP Photosmart C7280 Printer
Wireless printer won't print wirelessly.
Has the printer software been installed on the computer? Have you added the printer to your printer list on the computer?
Aug 24, 2009 | HP Photosmart 3310 Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
NETWORKING
yes of course you need a wireless router for that. wireless router are for wireless network (desktop pc also needs WAN)
Feb 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
296 people viewed this question
Ben Johnson
