Question about Refrigerators
Refrigerator not getting cold
We have a kenmore all frige, no freezer. 2 years old. The fan works and there is noise, the light works but is not getting cold.
  • 400 Answers
Sounds like your unit may be short of refrigerant. You say that there is a noise, I presume that this is the sound of the compressor running. You need to confirm that the compressor is actually running. To do this you must feel for vibration by touching the compressor (black dome at back of refrigerator) If it is running then more than likely it is short of refrigerant and would need to be recharged.
Posted on Mar 05, 2009
Hi we have a frige frezzer which is 6x3ft about 10 years old and its not frezzing or getting cold but the light and fan are still working?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | De Dietrich Refrigerators
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and frige dont get cold and making a noise
Hi Thanks For The Question. Is The fridge Cold.If Yes Check In Fridge For The Noise. If Not In Fridge Pull Fridge Away From Wall, Remove Back Panel Clean All Coils Thanks The Appliance Doc
Sep 12, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidare
only 5 years is important, sounds very much like you have a bad compressor, It's trying to start asn cant so it shuts down(therees the noise your hearing. 5 year manufacture warr. so see if you can find your bill of sale. and give manufacture a call
Mar 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
