Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Kenmore washing machine stops and there is a burning smell
My washing machine will run for one or two loads and then it stops. It produces a burnt rubber smell. After a while it will run again. I checked the coupler and it is fine. The machine is over 20 years old. Could it be the motor?
  • Whirlpool Master
  • 3,361 Answers
Your motor is tired.
Replace the motor or the washer.
Posted on Mar 05, 2009
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
Kenmore stackable washer will not drain burning smell
THE DRIVE BELT HAS BURNT UP AND NEEDS REPLACED
Aug 14, 2014 | Kenmore Washing Machines
Kenmore washing machine ultra fabric care model #92282800. Stop woking suddenly and smell like burned.
Thanks for choosing FixYa and welcome. You need to check the control panel. There is a good chance you can visually see some damage since you smelled the burnt smell. Check your belt(s) as well. Check to make sure the motor is running. Something inside may have burned up. If you have no power, check these below.
May 12, 2011 | Washing Machines
I have a westinghouse super capacity plus commercial washing machine. It spins on some washers and now has a burning smell to it
Unplug it and don't use it will be a burnt wire or the motor burning out there is a safety feature built into it which will cut the motor off after it gets hot so it wont start a fire. You will need a qualified technician come look at it and replace one or both sorry for the problem its giving you. Also if it is the motor they normally run $150 and up...
Jan 02, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore 70 series top loading machine will not drain and go into the rinse cycle what part needs to be replaced?
CHECK THE LID SWITCH, AND CHECK THE TIMER FOR A BURNED SMELL. IF SMELL PROBABLY TIMER. SOME WASHERS WOULD NOT GO INTO SPIN WITHOUT LID CLOSED, BUT WOULD AGITATE.
Mar 10, 2010 | Kenmore 22422 Top Load Washer
Washing machine burnt wires?
It could be that the drive belt was slipping and got heated up. Look underneath the machine to see if the belt looks burnt or shredded. There may be small pieces of rubber on the floor under the machine. If the belt is OK then the motor may have overheated (but usually there is an overload switch in it to prevent burning up.)
Jul 08, 2009 | Washing Machines
Kenmore washer burning smell after motor coupling replaced
I have the exact same problem, which is why I found this post. Did it stop, or did you find a solution?
Mar 21, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Hello i have a kenmore elite washing machine it wont spin or drain and i did smell a little burnt smell when it stopped working i think i may have put to much in it thanks j.munro.
you need to replace the motor coupling, take off the cabinet front, the pull the pump aside, then the motor, you will find the coupling right there about a $10-$20 part
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Apr 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
273 people viewed this question
Dan Webster
Dan Webster
Sal De
