Question about Microsoft Xbox 360 Console
3 flashing red lights but power cord is green
3 lights (all but upper right quadrant) are flashing red on the front. I checked the on-line fixes suggesting the power cord but it isn't that because its light is green (indicating normal). During game play or DVD, the screen works and then suddenly freezes with a red checker board overlay pattern.
Thanks for any help.....ain't looking too good
  • minge52 Mar 05, 2009
    Exacly the same... I had a problem last year with the red lights and system crash then i got it repaired games said it was a faulty h-drive and now its doing exactly the same thing! Why!?
  • 21 Answers
When someone say that his/her Xbox is having 3 red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Apr 07, 2009
  • 3 Answers
Most likly not a faulty hard drive or disk drive it is prolly that the system is overheating witch the x clamps are getting weak and letting the heatsinks slide up just enought that its pulling off the GPU or CPU if you had any overheathing befor this happened its exactly that and you need the rrod repair kit witch u can get for about $5.00 with new thermal paste( use new paste) just go on youtube
Posted on Apr 06, 2009
  • 81 Answers
Hardware problems give to repair
Posted on Mar 05, 2009
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
Red Ring Around the Green Button
RED RING OF DEATH syndrome
CLICK HERE for information about getting it repaired by microsoft.
Basically it involves dis-assembling the unit and replacing the thermal paste between the CPU and Heatsink.
CLICK HERE for a TOWEL remedy.
THIS may work as an NO-TOWEL alternative.
Thank you for using FixYa - a FixYa rating is appreciated!!
Feb 08, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
When i turn on the xbox360 three red lights come on around the on button
if its three lights with the right upper quadrant not lit then you have the RROD..red ring of death..call microsoft and get the console replaced..i had three consoles replaced..before calling them do check if the cables are properly connected..questions which customer care asked me where: what is the light status on the power brick?green...is the power cord directly connected to the mains?yes..have you modified the system?no
i got mine within 4 days.eeb0cb0.jpg this is the image of the infamous RROD!hope it helps..
Oct 29, 2008 | Computers & Internet
I keep getting three red rings in the part where it shows how may controllers are playing and i can't get any of my games to play or my controllers to work
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console.
You can try one or two things.
1. Turn on your xbox and check to see if the power supply light is green. If it is green there is a problem with the system. If it is red it means you should check your connections and restart the xbox.
2. These rings have a tendency of meaning that there is a problem with the system itself. Most companies sell extra insurance to cover this "ROL" Ring of life. You can contact Microsoft by calling them. The number is usually listed on the back of the video game booklets.
I wish you the best and I hope this resolved your problem
Happy Gaming
http://support.microsoft.com/kb/907534
Oct 18, 2008 | Video Game Consoles & Games
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
135 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
