Question about Canon MultiPASS F50 All-In-One InkJet Printer
Multipass F30 - Paper Feeding Problem
Pulls from one side only. Then jams since the paper is not going in evenly. No apparent blockage.
  • gregscheer Mar 07, 2009
    Thanks for the suggestion. However my model does not have a document feeder. But, that gives me an idea and I'll see if I can get to the rollers and if the problem lies there.
  • 2,120 Answers
Open up the document feeder and clean the scanner glass
Posted on Mar 05, 2009
Paper jams does not deliver P light comes on
check to see if a tiny piece of paper is blocking the paper path. also remove paper from the cassette(which pulls out from the front) and try feeding paper from the tray on the right side. Good luck.
Jan 11, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Paper not fully feeding from paper tray. stops
  • Check for jams
  • Make sure all rollers are rolling and feeding
  • Make sure you using the manufacture required paper weight.
If none of the above applies to your issue you might have a bad feeder the paper is getting jammed mid way or there could be something inside blocking it half way thus your printer will need good maintnance.
Please do leave positive ratings for your free solution today.
Nov 17, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Printer won't feed paper
The unit does not power on.
(1) Check the power cord
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
Oct 09, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper not feeding correctly
sounds like there is a piece of ripped paper in the printer
Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
When trying to print paper pulls to the right and jams
try feeding the paper first, mine pulls to the right also, but if I hold it when is jerks, sometimes it will not jam
Dec 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper Jams
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 27, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Paper feeder pulls paper incorrectly
A few possibilities exist: Look for something jammed in the paper path- by chance a paper clip, extraneous piece of paper, or even a broken piece of the printer itself. I'd guess there is a multi-section roller which pulls the paper, perhaps one section is slick- a tiny bit of oil or something on it. Something sticky (spilled pop) can goof things too. Anything amiss in paper path will foul up the paper feeding properly.
May 03, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
Canon MultiPASS F50 All-In-One InkJet Printer Logo
95 people viewed this question
old marine
old marine
